Rear Main Seal Leak - Defender Source
Old June 18th, 2016, 09:27 PM
joyride8
Logan Feldman
1997 D90
Rear Main Seal Leak
i have a slow leak from my rear main seal. ive gotten numerous quotes and am debating if the repair is worth it or just keep an eye on oil levels, i use the car maybe once a month . thoughts and feedback greatly appreciated. (97 automatic)
Old June 18th, 2016, 10:54 PM
Naplm00
Matthew
Depending on how much really. Dime size after a week? Who cares... Puddle? Different story
What kinda quotes did you get?
Old June 19th, 2016, 12:23 AM
D90rovin
95 NAS SW
on my last D90 the leak wasn't too bad but I ended up having it done. If I recall it was like $1500+ and the shop told me they didn't guarantee the repair.... So it could stop leaking for a day, a week, or a year but luckily I didn't see the leak again while I owned it.
Old June 19th, 2016, 07:31 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Buy a black mat to put under your truck and Relax.
Old June 19th, 2016, 09:06 PM
joyride8
Logan Feldman
1997 D90
ironically i got 3 different quotes from 3 different dealers ranging from 2300 to 3000, and my local mechanic quoted 1900
Old June 19th, 2016, 09:29 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
As mentioned before, if it's a small leak it's not worth paying the price to fix it. Throwing good money after bad. The reality is that most leak or weep and many did from new.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old June 19th, 2016, 11:31 PM
Naplm00
Matthew
Yea that's bonkers. Especially since you don't even need to pull the engine or drop tge Trans and tcase. Take out the floor and Trans hump, unbolt drives haft and mounts and shuffle it back on the Crossmember.
Old June 20th, 2016, 12:44 AM
It is not the rear main, or at least 90% of "rear main seal leaks" are fixed by replacing the crucifix or cross seals.
------ Follow up post added June 20th, 2016 12:44 AM ------
Oh, and service the PCV system, new hoses etc.
Old June 20th, 2016, 06:56 AM
I've also seen the cam plugs on the back of the block leak.
Old June 20th, 2016, 09:16 AM
Grover's Avatar
Grover
I've been dealing with a leak from the rear main for 11 years (since I bought it)
I've traced to where the rear main cap mates to the block. I plan on replacing the cross seals soon. During the 11 year drip, I've re sealed the oil pan several times thinking it was the pan. I also tried blue devil seal conditioner. This stopped the drip for about 100 miles, then it came back.
Good luck!
Old June 20th, 2016, 12:32 PM
1of40's Avatar
1of40
1of40
Almost 14 years ago I found an ad from a guy that was selling his NAS 90. It had about 30k miles and he was being forced to sell it. His wife was sick and tired of it dropping dime sized marks on their cobblestone driveway. He'd had Peabody LR replace all major seals and they lasted for a year before it all started over again. She nagged him to a point where he was like take this thing. So I flew up to Boston, drove him back to Marblehead and headed back to DC. It's has dripped for 14 years but still going strong.
Old June 20th, 2016, 12:52 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
That's exactly what Charlie from Roanoke told me....he may have said 95%!
I still need to do mine....
Rent my
Old June 20th, 2016, 11:57 PM
chrisconnie's Avatar
chrisconnie
Adam Hairston
97 LE #127/300
x2 on the cross seals. I fixed my leak that the dealer told me was the rear main.
Old June 21st, 2016, 04:41 PM
UserName's Avatar
UserName
Andy
Janey
Matthew, can you elaborate on this technique a little? Would you leave the exhaust pipes in place, not need to disconnect the clutch slave, e-brake, etc? I was thinking of dropping my transmission to do this but if it could just be slid back enough to access the flywheel (and ultimately the rear main seal) while balancing somehow on the crossmember that would be great!
Old June 21st, 2016, 04:54 PM
Naplm00
Matthew
Got the idea from Here
https://www.landyzone.co.uk/land-rov...change.174080/
Old June 21st, 2016, 06:15 PM
I would pull the motor to do it. I find that faster than pulling the transmission. I've never heard of anyone doing it without pulling both, but I suppose anything is possible.
Old June 22nd, 2016, 07:41 AM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
^^^^^^ this
Mine has leaked for 6 years...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Rear Main Shaft Seal, how far back to drift in? Neil McCauley Defender Technical Discussions 4 September 12th, 2009 01:28 PM
replacing 3.5L V8 rear main oil seal cgalpin Defender Technical Discussions 9 June 18th, 2008 01:03 PM
Rear Main Seal Heath Defender Technical Discussions 1 March 15th, 2007 11:13 PM
Rear main seal replacement howellm70 Defender Technical Discussions 4 May 20th, 2004 07:33 AM
