Rear LED light install question - Defender Source
Old June 19th, 2014, 04:21 PM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
I'm finishing up my rear LED light install and when I pulled off the reverse light, the wires were dangling and not connected to anything. I believe I found the correct wire on the loom ( green//brown stripe) but it's not showing any voltage.
My question is, does the truck need to be running and in reverse for the light to work or will it work with the engine off and lights on?
Matt
Old June 19th, 2014, 04:26 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
On and in gear
Jimmy Buffett
Old June 20th, 2014, 05:39 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
To clarify I imagine the +12v would be on with the lights and the transmission switch would open the circuit (I.e) on. I would presume it's the +12v feeding through the transmission case switch (but it could also be the ground)
Old June 22nd, 2014, 09:01 PM
flananuts
Matthew
Appreciate it. Looking forward to fixing it.
Old July 5th, 2014, 03:17 PM
Nashville's Avatar
Nashville
Victor Hess
1997 Defender 90 NAS
Did you put resistors in? When I installed the kit from RN the lights don't work right. The only light that is fine is the reverse light. I added a relay when installing the front driving lights and signals. I'm giving them a call Monday to see.
1997 D90 ST NAS #1426
British Racing Green
Old July 5th, 2014, 03:29 PM
LED's need to be wired correctly. If you mixed the positive and the negative for each lamp the are not going to work. Drag out your multimeter and check the polarity.
Old July 5th, 2014, 04:27 PM
Ignition in on position and gear stick in reverse to supply power to the light.
The other lights have nothing to do with the reverse light.
Old July 7th, 2014, 06:36 PM
flananuts
Matthew
To answer the other questions, I installed the wipac relay and wired the led's up without any resistors. Straight forward install with no issues. Bought the lights through Lucky8llc. Thanks for the help on the reverse.
Old July 7th, 2014, 10:21 PM
Got relay from superbrights
Old July 13th, 2014, 01:47 PM
Nashville's Avatar
Nashville
Victor Hess
I used the Wipac relay for the front signals, but after installing the rear lights, the resistors from RN did the trick perfectly. I bolted them to the inside of the rear bumper.
It turns out my brake lights did indeed have wires in the wrong places. Once I switched them around all works perfectly. I ended up with white/red/black from left to right.
ht
Safari Dust LED light kit? tebby Misc. Chit-Chat 10 January 5th, 2011 01:01 AM
Reverse led light part # needed FlaD90 Defender Technical Discussions 5 July 16th, 2010 08:35 PM
New LED rear tail & stop light bulbs FlaD90 Smaller Projects 2 July 21st, 2008 02:10 PM
LED running light bulbs JBfoot Defender Technical Discussions 23 April 12th, 2008 05:53 PM
License Plate LED Lamp & Rear Fog Lamp Install LenB Smaller Projects 24 December 16th, 2007 08:54 PM
