rear latch lock cylinder removal... help! - Defender Source
Old December 11th, 2012, 06:53 PM
Rowdy90
Chad yates
97 D90
I've lost the door key to my 97 defender 90 and I am having trouble removing the lock cylinder on the rear door. The workshop manual says I have to use the key, which I don't have. Anybody know how I can remove the cylinder without the key?
Old December 11th, 2012, 07:19 PM
Try any key
Old December 11th, 2012, 07:23 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I think you have to drill it out. I know I had to do this before to change the lock cylinder.
Robert Deniro
Old December 11th, 2012, 07:32 PM
Rowdy90
Chad yates
97 D90
I was afraid of that... I can't find the key so I can't turn it to line up the pin... I'm sure this is going to be an adventure... Thanks for your response Neil!
Rear Door Lock puzzle Overlander Defender Technical Discussions 9 July 15th, 2007 01:23 PM
SW rear door latch mechanism roverboy For Sale - Parts 8 March 22nd, 2007 02:42 PM
Re-Sleeve ing Rear Brake and Clutch Master Cylinder COSteve Defender Technical Discussions 12 June 24th, 2006 12:33 AM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
diif lock inquiry rover4x4 Defender Technical Discussions 16 February 6th, 2004 07:35 PM
