rear hub gaskets, Right Stuff & seal direction - Defender Source
Old May 29th, 2009, 11:33 PM
cdb
Clark Bowen
rear hub gaskets or Right Stuff
I use Right Stuff for my differential to axle case gasket - is there any reason I couldn't a thin coat of the same stuff in place of the three gaskets on the rear hubs?
Clark
Old May 30th, 2009, 11:13 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
I use an actual gasket on the differential because it makes it easier to remove (trying to remove one thats been stuck in place with a whole tube of RTV is a pain, imagine how youll feel if you have to do it on the trail). The trick is to coat the gasket with chap-stick on both sides before bolting it together.
The drive flange gaskets almost have to have some (just a little) RTV or they will leak. I glue one to the flange, then another to that one, then the face of the flange gets, you guessed it- chap stick. A little 90w will work in a pinch, the point is to provide enough gasket thickness so it will seal and then keep it from permanently sticking to the hub so it can be reused when you do not have a spare on hand.
Old May 31st, 2009, 12:15 AM
cdb
Clark Bowen
Today the gaskets arrived from RDS so I just went ahead and used them. I liked Joel's chap stick idea so I'll use it too.
Thanks for the help.
Clark
Old May 31st, 2009, 01:00 AM
Hylomar is the ideal thing to use with the paper gaskets.
Old May 31st, 2009, 12:01 PM
cdb
Clark Bowen
Thanks Ron and I have lots of Hylomar around. I'd forgotten about it.
gas, gaskets, ht
Inner hub seal seating depth KevinNY Defender Technical Discussions 32 September 12th, 2009 02:05 AM
rear hub gaskets or Right Stuff cdb Defender Technical Discussions 1 May 30th, 2009 12:23 AM
Which direction to install rear outer hub seal? cgalpin Defender Technical Discussions 16 September 23rd, 2005 12:06 AM
