rear hub gaskets or Right Stuff - Defender Source
Old May 29th, 2009, 11:42 PM
cdb
Clark Bowen
I use Right Stuff for my differential to axle case gasket - is there any reason I couldn't apply a thin coat of the same stuff in place of the three gaskets on the rear hubs?
Clark
Old May 30th, 2009, 12:23 AM
d90dan's Avatar
d90dan
Dan Berry
1995 D90
I've used right stuff on axle hubs on the series II. No leaks, just make sure that you have a big screw driver and hammer the next time you need to remove them.
FYI, I use right stuff on my buick race motors and its the best oil sealer I've found.
gas, gaskets, ht
Separating rear rotor from hub kolvedic Defender Technical Discussions 4 September 26th, 2009 09:03 PM
rear hub gaskets, Right Stuff & seal direction cdb Defender Technical Discussions 4 May 31st, 2009 12:01 PM
Garage Sale: Disco And Defender Stuff ember For Sale - Parts 5 October 4th, 2005 12:24 PM
Which direction to install rear outer hub seal? cgalpin Defender Technical Discussions 16 September 23rd, 2005 12:06 AM
» Defender Registry
90
clb1994
#170
bcoffeya
Add your Defender
