rear half-shafts question - Page 2 - Defender Source
Old October 28th, 2014, 12:18 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Hey guys, sorry to hop on your thread but I was wondering...
I bought some half shafts from lucky8 and the Ashcroft website says something about removing one of the oil seals to allow the oil to get to the whole shaft... Any clue what that's about?
Old October 28th, 2014, 10:17 AM
Later axles have a seal on the half shafts. This prevent oil from reaching the drive flange splines and hub bearings.
Old October 28th, 2014, 10:37 AM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
as in...
later than 95?
Attributed to Shayne...
Old October 28th, 2014, 10:49 AM
The change was around 1992/93 when they went to the narrow hubs. Item 3. You don't need to remove it. Ashcroft is suggesting it as the dry splines have known wear problems in the stock vehicles. Many people also feel oil filled bearings are better.
Old October 28th, 2014, 07:49 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
They won't warranty it if it goes...what keeps the oil in if you take the seal out?
Old October 28th, 2014, 11:42 PM
jafir's Avatar
jafir
Jafir Elkurd
#14 in the photo
Old October 28th, 2014, 11:56 PM
I'm not sure if you are serious. What warranty??
In any case, #7 is the hub seal, FTC4785. It is best to switch that for an OEM RTC3511. RTC3511 is a better seal and what was used back in the day when the hubs where oil fed.
Old October 29th, 2014, 12:00 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
I'm not sure if you are serious. What warranty?? In any case, #7 is the hub seal, FTC4785. It is best to switch that for an OEM RTC3511. RTC3511 is a better seal and what was used back in the day when the hubs where oil fed.
Ashcroft warranties their half shafts for 5 years but won't if they wear at the hub because of lack of oil...hence the suggestion of pulling the seal.
Old October 29th, 2014, 12:01 AM
I'm not sure if you are serious. What warranty??.
ashcrofts most likely
Old October 29th, 2014, 01:41 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I ditch the #14 gasket and use Right Stuff-- just clean off old gasket first.
Old October 30th, 2014, 11:26 AM
kevincdoyle
Kevin C. Doyle
Holy smokes!!!!!
Just called dealer for a couple of items I need:
rear half-shafts-$730.63....each!! 3 weeks out from England
Ignition lock.....wait for it........ $377.26
I'm going to sell this Defender piece by piece.....
I'll have a fortune shortly...
Anyway, better place?
RN, Safari...anybody else to check?
Thanks Board!
KCD
Old October 30th, 2014, 11:32 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Yikes... I recommend the ashcrofts, and L8 has great pricing on them
Old October 30th, 2014, 11:33 AM
jafir's Avatar
jafir
Jafir Elkurd
I'd call Marty or Will for the shafts. I don't see any reason to put new in it with how cheap used will be. If you want new, any of the places you've mentioned will have halfshafts, probably for less than $200 each. http://www.rovahfarm.com/
Or put upgraded ashcroft shafts in.
Old October 30th, 2014, 11:35 AM
I have two used shafts you can have for very cheap.
Ignition lock, just get a non-US version (no seat belt chime), should be about $125 or so.
Old October 30th, 2014, 11:39 AM
http://www.rovahfarm.com/defenderaxlesandsuspension.htm
$240 for both shafts.
$280 at RN
http://www.roversnorth.com/ProductDe...=PLF581&type=0
http://www.roversnorth.com/ProductDe...455&type=0&eq=
Shop around or ask on here for used ones. Or get the Ashcroft ones.
Old October 30th, 2014, 11:44 AM
kevincdoyle
Kevin C. Doyle
L8 website or
contact info?
Thanks much!
------ Follow up post added October 30th, 2014 03:45 PM ------
I think I'll go with new or the Ashcrofts...just don't know the stress used ones may have endured and don't want to be here again.
KCD
Old October 30th, 2014, 11:50 AM
Originally Posted by kevincdoyle View Post
contact info?
Thanks much!
See earlier in this thread.
Sure, it is that easy. It is designed to be easy, to be repaired in the bush.... Just stop fighting it. You own a Defender and it will hate you until you learn how to work on it.
USA source, although you should never be scared of buying from the UK....
http://lucky8llc.com/Products.aspx?ProductID=2192
http://lucky8llc.com/Products.aspx?ProductID=2194
Old October 30th, 2014, 11:52 AM
kevincdoyle
Kevin C. Doyle
Thanks very much guys!!
I'll be back in a week or two with report....
Old October 30th, 2014, 11:53 AM
As discussed earlier though, you should first pull the shafts to make sure that a broken shaft is the problem. It could be the diff as well.
Old October 30th, 2014, 04:02 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Just called dealer for a couple of items I need: rear half-shafts-$730.63....each!! 3 weeks out from England Ignition lock.....wait for it........ $377.26 I'm going to sell this Defender piece by piece..... I'll have a fortune shortly... Anyway, better place? RN, Safari...anybody else to check? Thanks Board! KCD
Did that includes the Vaseline?
Rear half Shafts / F&R Drive shafts ( stock ) Rugbier For Sale - Parts 2 September 24th, 2011 09:56 AM
ARB 3rd member, Great Basin Half shafts rear ron For Sale - Parts 17 June 4th, 2010 08:47 AM
GBR HD rear half shafts jvelador For Sale - Parts 8 August 13th, 2009 04:31 PM
heavy duty rear half shafts CDeWan Wanted 1 January 29th, 2009 06:43 PM
Stock diff, stock rear axle half shafts..... nilesj For Sale - Parts 5 October 15th, 2004 11:10 AM
