Rear half shaft play ... - Defender Source
Old May 4th, 2009, 04:45 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Any one know how much play is allowed in the rear Salisbury half shafts ? I seem to have allot, about 3/16" on each side, see pics attached .
Pat
ID:	19273   Click image for larger version
Kirk Lazarus, Tropic Thunder
Old May 4th, 2009, 06:05 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Pat, there should be almost zero play in the shaft however there must be a small amount of backlash in the diff, i can look up the figure if you want but it requires a rebuild on the diff to set up properly.
The play you are feeling is most likely due to wear in the splines on the half shaft at the diff end and the drive members on the hub.
A new drive member normally removes any play and associated clunk when pulling away, though it is worth removing the drive member and pulling the shaft to check the spines.
regards
Gren
Old May 4th, 2009, 06:13 PM
Retrofit's Avatar
Retrofit
Pat
Thanks Glen, I hope the half shafts last me all summer long as I was planing the ARB for the end of the summer.
Crossing my fingers.
Pat
Old May 4th, 2009, 06:19 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
doh sorry pat i was thinking one thing and typed something completely diffrent, jeez must be having a grey moment.
I just checked the play in mine and its about 3mm, can just get the edge of a small flat blade between the drive member and circlip.
regards again.!
gren
Old May 4th, 2009, 08:59 PM
Normal and fine.
Ron
Old May 5th, 2009, 08:11 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
they make shims to put between the c-clip and the flange to take up the play.
Legend in My Own Mind.
Old May 5th, 2009, 10:44 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
In this case it would be a couple of washer's!
Like Ron said the end float is fine Pat, pretty normal. In fact on the Toyota kit I let the axles float where they please, distance is controlled by the length of the spline and the cross pins in the diff. And a very close total length tolorance.
Keith
Big, Red and ... aaa Red..
rear half shaft jimmy salmon Wanted 1 February 21st, 2008 12:54 PM
24 Spline Axle Shaft (Long Side) + CV Joint + Rear Housing mudrover For Sale - Parts 0 March 2nd, 2005 09:48 AM
Used rear drive shaft dmarchand For Sale - Parts 0 October 15th, 2004 11:30 AM
Stock diff, stock rear axle half shafts..... nilesj For Sale - Parts 5 October 15th, 2004 11:10 AM
