Rear frame question - Defender Source
Old September 27th, 2010, 06:48 PM
waggoner5's Avatar
waggoner5
Gary Waggoner
1965 custom
Rear frame question
What is the large recessed hole in the frame of my 110 used for?
1963/2008 Defender Crew Cab
1965/1997 FJ45 Pick up
Old September 27th, 2010, 06:49 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
future rust.
Old September 27th, 2010, 07:04 PM
waggoner5's Avatar
waggoner5
Gary Waggoner
1965 custom
Ah....cool. Maybe I should cut it out now then.
Old September 27th, 2010, 09:05 PM
kzack's Avatar
kzack
Keith Zack
none
I believe it to be clearance for a power take off shaft.
Keith
Old September 27th, 2010, 09:47 PM
waggoner5's Avatar
waggoner5
Gary Waggoner
1965 custom
Ah...That makes sense. Thanks.
Old September 27th, 2010, 11:52 PM
This is a modern frame? Is the hole rececessed (i.e. doesn't go through) and slightly off to the right? That is usually used for the trailer hook up. You can't have a PTO with a hole that doesn't go through the chassis and you can't run a PTO shaft through the gas tank anyway.
Old September 28th, 2010, 12:02 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
If you have a TD5 chassis then it is the trailer plug location.
Old September 28th, 2010, 06:40 PM
waggoner5's Avatar
waggoner5
Gary Waggoner
1965 custom
Sounds like trailer hookup. Thanks all.
rear light electiral hook ups paulb Defender Technical Discussions 25 January 19th, 2010 03:25 PM
Quick fix-torn boot- rear a frame diff joint? J.P. Defender Technical Discussions 0 September 17th, 2008 09:08 AM
rear cross member replacement question Cirbo Defender Technical Discussions 16 May 25th, 2008 01:04 PM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
