Rear Fog Light Electrical Fault - Defender Source
Old March 29th, 2015, 02:46 AM
nengelbrecht6's Avatar
nengelbrecht6
Nick Engelbrecht
2005 LR3 SE "No Name Yet"
The rear fog light on my 1985 110 CSW will not work. Yesterday, I verified that there was 12 volts present at the switch (Purple+Blue wire) with the low beams on but this voltage drops to zero when I turn the fog light switch on. I tried disconnecting the lamp unit thinking that maybe that could be the issue but still the same results. I also checked the grounding wire, but that is good because it is a common ground with all other tail lamps and all the others work.
I'm out of things to check and am seeking some advice if anyone has any.
Old March 29th, 2015, 03:08 AM
nengelbrecht6
Nick Engelbrecht
I should also add that the indicator on the dash also does not light.
Old March 29th, 2015, 09:35 AM
The switch may be bad... Do you have any power past the switch? Try jumping the switch to see if the fog light comes on.
Old March 29th, 2015, 03:18 PM
nengelbrecht6
Nick Engelbrecht
I've tried jumping the switch with the same results. I don't suspect it is the switch.
Nick
KM6FDZ
2005 LR3 SE
Old March 29th, 2015, 07:58 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
On the later years the Blue/Purple wire comes from the fuse box to feed the Fog light ECU. A red/slate goes to the switch which completes a ground circuit. Out of the ECU comes a RY wire that goes to the dash lamp and the fog light.
I would double check to make sure you do not have a relay or something behind the dash that is faulty.
electrical, ht
Reverse light / fog light gremlins tim Defender Technical Discussions 10 November 1st, 2014 11:26 PM
Electrical Fault WTF - Lights turn car on?? Video included rijosho Defender Technical Discussions 13 March 12th, 2012 11:43 AM
New ROW backup light and Fog light dave_lucas For Sale - Parts 2 June 2nd, 2010 07:38 PM
1995 D90 - Found an electrical fault - now what? clancelotta Defender Technical Discussions 0 August 23rd, 2008 07:35 PM
Fog light install SFD90 Defender Technical Discussions 15 January 13th, 2004 10:51 PM
