Rear end rotting out Defender 90 - Defender Source
Old May 11th, 2011, 06:08 PM
WOVOKA
Lou Severino
Hello my rear end is rotting out and I have some leakage.
-- Let the jokes begin--
But seriously it is a 1994 D90 3.9 5-speed and the rear end is looking pretty bad. I was wondering what my options were. Can I just find the housing and replace it? Who might have one for me? Will a rear end off an automatic discovery work or are the gears set different? What is my best route.
Lou Severino
Old May 11th, 2011, 07:31 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
The rear diff cover on my 88 rusted through years ago. I made up some nice, thick epoxy goop and (after appropriate cleaning) spread it on the cover. It was a quick and cheap repair.
John Karlsson
Hope Valley, RI
Old May 11th, 2011, 08:30 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
The make replacement caps for them, seems a common problem in the UK. You cut the old one off and weld a new one on. You could check some of the vendors here to see if they could get one for you.
Land Rover 110
Old May 12th, 2011, 02:50 PM
TS888's Avatar
TS888
Tony Sims
1984 110
Disco or RRC rear axle is a straight swap. All coil spring LR's have 3.54 ratio.
Tony
1984 110 "Smokey" (sold)
Old May 13th, 2011, 10:43 PM
WOVOKA
Lou Severino
Thanks for all your help. Think I am going to try and replace the rear cap. I was able to find a few place that has them. I didn't even know this was an option. I appreciate all the help -- thanks John, Tony, and Mike
Old May 13th, 2011, 11:04 PM
Welcome back to the site...
Old May 13th, 2011, 11:22 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Might as well put on a pipe-cap while you're doing it. At least then there's a lot more metal to corrode.
90, d90, defender 90, rear end, rotting out
defender 90 rear cage aschaefer Wanted 8 October 21st, 2010 11:23 AM
Modified 1995 Defender 90 jdb3760 For Sale - Vehicles 23 April 21st, 2009 09:40 PM
1995 Defender 90 ST 2468 with 43000 miles EXCELLENT CONDITION funrover For Sale - Vehicles 1 September 25th, 2008 08:52 PM
Need a 90 Rear Step Bumper SafariHP Wanted 1 April 2nd, 2004 09:21 PM
