Rear end out of line? - Defender Source
Old June 1st, 2010, 12:46 PM
slatelacy
Slate Lacy
94 ST
I just had an alignment done at a local shop. The rear end toe is -.47 on the left rear and -.56 on the right. They said they would expect the truck to pull badly. I havent really noticed anything. Anybody have any ideas? We did just install a wolf rack, new shocks and 1.5 spacers....
Old June 1st, 2010, 01:15 PM
Based on my limited experience of seeing solid axle rovers on four wheel allignment racks, that seems about normal to me.
Old June 1st, 2010, 04:54 PM
LRover's Avatar
LRover
J. Michael McCaig
Yeah I agree. You can just about do an alignment with a tape measure as the only adjustment is to toe on the front axle. If it doesn't pull or wear the tires badly then just drive it.
Old June 2nd, 2010, 09:21 AM
slatelacy
Slate Lacy
94 ST
Thanks guys. I think we fixed it. Cranked down on the rear arm bolt and everthing measured up even. We'll see I guess. I appreciate the info.
Old June 2nd, 2010, 09:53 AM
How would that effect toe in?
Old June 2nd, 2010, 10:27 AM
slatelacy
Slate Lacy
94 ST
We measured from front center wheel to rear center wheel on both sides. Before we did anything, there was a 3/4 inch difference I think. After we tightened the arm bolt, both sides measured exactly the same. Since I just had the front end lined up, I figured they would be the same now.
rear end
Help! 110 Rear End Swaying. Neil McCauley Misc. Chit-Chat 24 June 4th, 2008 03:45 AM
weak rear brakes? redrover Defender Technical Discussions 12 April 28th, 2006 09:24 AM
Rear anti rock redrover Misc. Chit-Chat 11 March 22nd, 2005 08:43 AM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
