Rear end clunk? - Defender Source
Old January 3rd, 2014, 05:05 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Rear end clunk?
Did a search but could not find anything. This past weekend I noticed a clunking out of the rear suspension while going over speed bumps etc. Any ideas?
Thanks Guys!
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old January 3rd, 2014, 05:11 PM
Originally Posted by Burke View Post
Did a search but could not find anything. This past weekend I noticed a clunking out of the rear suspension while going over speed bumps etc. Any ideas? Thanks Guys!
A frame bush.
Old January 3rd, 2014, 05:24 PM
A frame bush.
Is this what yours is too or is that one still being tracked down?
Old January 3rd, 2014, 06:10 PM
mine seems fine ... I pulled every bolt and checked every bush underneath my truck ... And I mean every.
I'm thinking to put new springs, shock mounts and towers next ....
Baffled as to what it could be .... It sounds like something hitting the body ...
Old January 3rd, 2014, 07:10 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Thanks, where should I check, and how tough is the fix?
Old January 3rd, 2014, 07:21 PM
http://www.repairmylandrover.co.uk/d...ljoint-renewal
you can buy the unit with carrier and ball joint as one now reducing the difficulty.
Old January 3rd, 2014, 07:26 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Thanks! Is this common? Had my 90 since '94 and have never messed w suspension.
Old January 3rd, 2014, 07:57 PM
it's not uncommon ... you could always test it ...
http://forums.lr4x4.com/index.php?showtopic=45050
Old January 3rd, 2014, 08:10 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Seems there was a manufacturer of these that made a really robust replacement for this part. I cant remember who or when I read it but it was on this site.
Old January 3rd, 2014, 08:19 PM
Like this adjustable one?
http://foundry4x4.co.uk/index.php?ro...product_id=207
I'm guessing that most of these have lasted around 100k miles or more in NAS defenders .... I wouldn't be too worried about needing an expensive adjustable unless I was going off road ... Which I don't as NYC boost club member. ;-)
Old January 3rd, 2014, 08:30 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
You might want to also check your rear trailing arms bushings.
Old January 3rd, 2014, 08:37 PM
Bill Larson
Bill Larson
Yeah kinda...but that's not it. I need to find it within the next few months because I'm going to do mine when I change out the rear springs.
Old January 3rd, 2014, 08:39 PM
does it rattle worse on washboard type surfaces? ive replaced two worn a frame bolt joints, neither ever made noise other than a little squeaking.
id spend a little money on this part, there is a plenty of cheap replacements out there i went cheap fuck and it needs to be replaced again after two years
Old January 3rd, 2014, 10:05 PM
jhhorse
joe heins
1995 defender 90
Check your U joints! I had clunking over bumps and when starting out in first gear. Pulled rear drive shaft, aft ujoint nearly disintegrated.
Joe
Old January 4th, 2014, 07:52 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Check your shock bushings as well. Seems the top bushes go and give the same symptoms you've described for me.
Clay
Old January 4th, 2014, 10:41 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Was it this one? I was just looking at it yesterday
http://www.lucky8llc.com/Products.aspx?ProductID=7058
Does anyone have experience with this one?
Old January 4th, 2014, 11:01 AM
Originally Posted by Jpayne View Post
Was it this one? I was just looking at it yesterday http://www.lucky8llc.com/Products.aspx?ProductID=7058 Does anyone have experience with this one?
thats the same as the one I posted further up ...
Old January 4th, 2014, 11:02 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Duh... I was lazy
Edit
Old January 4th, 2014, 11:07 AM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
I have one in my truck. I haven't noticed a difference since I cant remember when the original in my truck was in good shape. Yesh, the truck now feels tioght like a tiger.
It does seem to be constructed a whole lot nicer than then stock one i'm putting in the disco.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old January 4th, 2014, 11:11 AM
Bill Larson
Bill Larson
yeah looks the same...I would buy from Lucky8...just because of the videos!
rear end
My rear end is sloppy WD90 Defender Technical Discussions 61 May 9th, 2014 10:59 PM
Salisbury Rear End JPBrown Wanted 11 October 5th, 2010 05:57 PM
Rear end out of line? slatelacy Defender Technical Discussions 5 June 2nd, 2010 10:27 AM
Detroit Locker for Sals. rear end kellymoe For Sale - Parts 3 February 20th, 2010 11:23 AM
weak rear brakes? redrover Defender Technical Discussions 12 April 28th, 2006 09:24 AM
