Rear end clunk? - Page 2 - Defender Source
Old January 4th, 2014, 05:12 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Found it. Both sides are loose? Can I simply tighten or do I need gaskets? And what is it?
Put plenty of releasing fluid. Liquid wrench and give it a good clean with a wire brush before attempting to undo it.
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old January 4th, 2014, 05:14 PM
It's the bottom of the shock absorber. You need bushes. The old ones are shot.
Old January 4th, 2014, 05:15 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Shock bushings....tightening might work, probably need replacing! time for some OME.
Old January 4th, 2014, 05:20 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Awesome! Thanks as usual guys!
Old January 12th, 2014, 12:57 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
ok, so showing my lack of wrenching skills, I cannot get this damned lower shock bolt off!!!! I got the drivers side off with several days of penetrating fluid and a 1/2 hour of trying, but pass side will not budge. Tried heat as well, and nothing. Problem is I cannot get my vise grips to hold the bottom of the bolt. Any suggestions?
Old January 12th, 2014, 01:28 PM
An impact gun can help. If you are replacing the shock you can put the vice grips on the body or shaft higher up but you'll likely damage the shock so don't try this if you are just replacing the bushing.
Originally Posted by pendy
I'm here for the D's
rear end
My rear end is sloppy WD90 Defender Technical Discussions 61 May 9th, 2014 10:59 PM
Salisbury Rear End JPBrown Wanted 11 October 5th, 2010 05:57 PM
Rear end out of line? slatelacy Defender Technical Discussions 5 June 2nd, 2010 10:27 AM
Detroit Locker for Sals. rear end kellymoe For Sale - Parts 3 February 20th, 2010 11:23 AM
weak rear brakes? redrover Defender Technical Discussions 12 April 28th, 2006 09:24 AM
