rear driving lights/brake lights LED problem - Defender Source
Old December 15th, 2017, 11:28 PM
fastinjun's Avatar
fastinjun
Mitch
ok, bought some led lights last week and got them today, put them in and turn signals work great..but the brake light/ driving light combo isnt working right. when I turn on the lights it lights up fine but they are too bright and there are no brake lights. I pulled the bulb from the housing and watched the different lights go on...Im thinking I got the wrong bulbs??? I got the ones according to what was suggested to me from here...I'll look at the model tomorrow.
Old December 15th, 2017, 11:48 PM
Naplm00
M
Did you buy bulbs or whole led assemblies?
If whole assembly, you may just have the brake and running lights switched
Old December 15th, 2017, 11:53 PM
fastinjun's Avatar
fastinjun
Mitch
bought just the bulbs. Turn signals work great...the red tail/brake light works as a brake fine as long as I dont turn on the lights...once they are on they shine bright and when I hit the brake there is no change. I reversed the wires thinking it was a polarity issue but still the same problem
Old December 16th, 2017, 12:02 AM
Naplm00
M
Do standard bulbs work correctly? If so then you are somehow putting them in reversed or the bulbs are incorrect
Old December 16th, 2017, 12:11 AM
Chris B
72 + D1 drivetrain =?
Or terminals in light are damaged causing bad connections....
Old December 16th, 2017, 12:16 AM
fastinjun's Avatar
fastinjun
Mitch
I'll try regular bulbs tomorrow and see...I tried reversing the terminal wires..no difference.
Old December 16th, 2017, 01:01 AM
Naplm00
M
True, incorrect terminals or broken ones
Old December 16th, 2017, 01:07 AM
speedpin's Avatar
speedpin
Looking ;)
You might have your brake and running light wires switched. So brake lights are on all the time... sorry..sounds like you tried that
~ Semper Fidelis ~
Old December 16th, 2017, 06:11 AM
Factoid's Avatar
Factoid
Mark
Three criminals seeking revenge
This doesnít make any sense. There are three leads for the tail/brake lights: tail, brake and ground. If you look at the base of the bulb, there should be two contacts that align with the two spring loaded contact in the light socket. These are the tail and brake +12v connections. One goes to the bright filament (brakes) and the other to the dim filament (tail). The case of the bulb is the ground. Switching the tail and brake leads is not switching polarity it is switching the signals. It sounds like the tail lights are connected to the bright filament. An easy way to check is to disconnect the tail light signal and depress the brake pedal. If it lights dimly, you found your issue.
One technical note, I realize LEDs donít have filaments.
1976 Series III 109 "Montoya" ("You killed my father, prepare to die")
1988 Defender 90 LHD "Vizzini" (speed demon from Sicily)
1987 Defender 90 MOD LHD "fezzik" (giant rock thrower)
1975 Porsche 911 hot rod
1964 Porsche (Beck) 904
Old December 16th, 2017, 08:37 AM
The bulbs fit only one way due to the little prongs being offset. If the regular bulbs were working the wires aren’t crossed. I think your led bulbs are either just crazy bright or they are faulty
Old December 17th, 2017, 12:12 PM
fastinjun's Avatar
fastinjun
Mitch
I checked again...I used the regular bulbs and the sequence worked fine..then put the leds in...They must be the wrong ones. I'll call the company or email them and explain the situation, hopefully I can return these ones if not just get the right ones
Old December 17th, 2017, 12:45 PM
Factoid's Avatar
Factoid
Mark
Did you look at the base of the bulb and verify there are two contacts?
Old December 17th, 2017, 02:00 PM
fastinjun's Avatar
fastinjun
Mitch
I did, standard 1157 bulb but it lights up white and yellow depending which wire gets power. I shouldve spoke with them before ordering
Old December 18th, 2017, 12:15 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
That's the wrong type of bulb. The white/yellow bulbs are designed for combination turn-signal/parking-running lamps.
You believe you want red/red 7528 bulbs.
Old December 18th, 2017, 01:21 PM
fastinjun's Avatar
fastinjun
Mitch
Thanks, I ordered the right ones this morning
brake, ht, lights, vin
1997 NAS D90 Indicator LED Lights issue MotoMando Defender Technical Discussions 3 September 3rd, 2017 06:14 PM
NAS Defender LED Lights landrovered Defender Technical Discussions 27 February 21st, 2012 08:44 PM
1995 & on NAS rear lights help.. FlaD90 Defender Technical Discussions 3 December 31st, 2008 06:06 PM
Defender LED Lights ColonialRovers For Sale - Parts 3 October 13th, 2007 10:51 AM
TOO MUCH STUFF, Disco/RRC/Series/Defender/P38 GARAGE SALE RedRhinoProducts For Sale - Parts 5 May 20th, 2006 08:19 PM
