Rear Drive shaft bolt size - Defender Source
Old April 9th, 2006, 05:30 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Hey guys,
I lost my bolts to bolt up the rear drive shaft. I need to get the 4 bolts that bolt the rear shaft to the transfer case drum. Does anyone know the exact size of the bolts? Thanks
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 9th, 2006, 06:45 PM
I replaced all of my stuff with grade 8 fine thread 3/8ths bolts and nuts, they are almost exactly the same size. I believe what you are looking for is M8 fine thread. But I have had trouble finding M8s that are 14mm on the outside.
Old April 10th, 2006, 12:36 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I think they are actually M10 fine thread. No matter, I found major damage inside the case break so I will be replacing the bolts anyway.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 11th, 2006, 10:10 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
3/8ths fine! If yuo use the gr 8 get them a little longer for the shoulder. cut off the rest
Old April 11th, 2006, 10:47 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
huh?
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 11th, 2006, 11:15 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
LOL let me try to translate.
3/8" bolts are fine. Use grade-8 bolts and buy them a little bit longer than needed. After assembly, cut off the excess length of bolt.
-Hans
My oil line fix
My 100k stopped odometer fix
Old April 12th, 2006, 01:20 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Thanks! But, why get them longer and then cut them off?
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 12th, 2006, 08:55 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
shoulder of the bolt. "not threaded part" it would be thicker than the threaded part. no need to assemble first mark a little longer than the stock one run a nut on & cut away run the nut off!
I like nylocks you can run nut & lock washer
Old April 14th, 2006, 10:05 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Got it all back together today. Ohhh, so pretty.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 14th, 2006, 11:11 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Down right sexy!
Old October 14th, 2006, 01:28 PM
on those bolts not the nuts will they fall off into that drum? I was going to take my driveshafts off to see if i can elimate a vibration front or back u joints.
Old October 14th, 2006, 01:32 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
The nuts inside the drumb are fixed and will not fall if you take the bolts out... is that what you wanted to know??
Old October 14th, 2006, 01:34 PM
okay well how about the bolts that bolt the driveshaft (thru the flange) will they fall into the drum? Or are they like studs and wont move (theoretically)
Old October 14th, 2006, 02:29 PM
D90user's Avatar
D90user
steve
Sorry... thats what I meant... the threaded bolts are fixed and will not fall in the drumb... go a head and take it off... it will be easy to get it back on.
Old October 14th, 2006, 04:20 PM
thanks.
Bolt size Rear bumper mwmorgan22 Defender Technical Discussions 0 February 1st, 2009 12:36 PM
bootyfab-ulous Drive shaft Buckon37s Misc. Chit-Chat 4 January 3rd, 2007 10:02 PM
What size is the a-arm bolt? cbass Defender Technical Discussions 9 August 22nd, 2005 11:59 AM
vibration around 20 mph Rick Carlisle Defender Technical Discussions 19 August 25th, 2004 07:41 PM
Bolt & nut size? Berty Defender Technical Discussions 7 June 3rd, 2004 06:26 AM
