Rear drive line length? - Defender Source
Old August 26th, 2014, 09:27 AM
Quimbola's Avatar
Quimbola
Josh
1994 #1695 Not stock.
Ordered a new Tom Woods rear drive line from lucky 8, it looks WAY to long, it says 35" on the tag, went and measured my old one,] it was a 29.
I assume 29 is about standard for 90's?
Maybe I was just sent the wrong one?
Thank you for any info.
-Josh
Old August 26th, 2014, 10:22 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
It depends on your suspension set up. If you have a lift then you need a longer one than the stock one.
That should explain the difference, but 6 inches sound like a lot.
Cheers
- Charles Eames
Old August 26th, 2014, 04:29 PM
Quimbola's Avatar
Quimbola
Josh
Confirmed they sent the wrong one. Looks like the new one will be a 29, I do have an OME lift.
Spline drive bolt thread pitch and length Chris Velardi Defender Technical Discussions 0 March 9th, 2012 11:22 AM
Front brake line - why hard line & flex line? jefhuf Defender Technical Discussions 5 January 13th, 2012 09:03 AM
Stock front drive shaft length? D90user Defender Technical Discussions 4 September 29th, 2009 02:46 AM
rear drive shaft length? Gkase Defender Technical Discussions 0 October 9th, 2008 05:46 PM
Extended Length Clutch rubber line? Antichrist Defender Technical Discussions 7 November 24th, 2006 11:40 AM
