Rear Door Lock puzzle - Defender Source
Old July 12th, 2007, 10:56 PM
My NAS 110 rear safari door lock does not have or seem to ever have had the tab allowing the door latch to be locked/unlocked from inside the vehicle. Pics I've seen of that door latch mechanism on other defenders have the little latch that can be worked from inside.
Is this an NAS 110 thing? A 93' thing? Or what?
Old July 13th, 2007, 09:33 AM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
My early '94 90 has a smal black tab that sticks out of the locking mechanism. It flips up to lock. Very high tech!
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old July 13th, 2007, 10:21 AM
Burke,
That's a SW right? If so, can you take a picture of it for me? I want to know if somehow mine broke off or not.
Old July 13th, 2007, 10:23 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
NAS 110s did not come with the internal lock/unlock device.
You can retrofit the later style easily by just swapping the parts. You will need the new latch (part # FQJsomething) and to either cut a groove in the plastic cover, or also get the later D90SW plastic trim.
Email:
Old July 14th, 2007, 01:16 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Soooooo..... The NAS 110's could only be locked/unlocked from the outside. the NAS D90's could only be locked/unlocked from the inside. If you wanted both, you had to get the replacement latch.
Wierd. LR sure doesn't make any sense sometimes.
My oil line fix
My 100k stopped odometer fix
Old July 14th, 2007, 01:40 PM
themaxx's Avatar
themaxx
Ade
94 ST
My 97 SW locks/unlocks from both inside and out.
Old July 14th, 2007, 04:06 PM
Epsom_D2
Sean-Paul Ferrera
1994 D90 POE
As does my 94 SW
Old July 14th, 2007, 05:14 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
94 STs were only lock from the inside. This can be a major PIA when the truck is loaded. Or for that matter when anything in the back lodges against the inside handle.
"Uhh...I think they all leak like that."
Old July 15th, 2007, 11:30 AM
oldgreentrucks's Avatar
oldgreentrucks
Jim Pace
Yes early 94 D90 was only locked/unlocked from the inside. Major PIA if you want to lock it. Later (VIN?) 94 and up had outside access. To change over you need new lock and cut additional hole for the key.
Jim
Old July 15th, 2007, 01:23 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
My '95 D90 ST (NAS) can be locked/unlocked from the inside/outside. I'd hope/think you can use the existing lock and retrofit it in the new(er) assembly. Worst case scenario..... use a small file and make it work with your key! ;-)
MonLand
1995 D90 NAS
1996 Discovery NAS
door, rear door
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
Rattle From Rear Krna Defender Technical Discussions 3 July 26th, 2004 11:50 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
