Rear door inner panel - Defender Source
Old October 15th, 2004, 02:13 AM
Kimos's Avatar
Kimos
Larry O'Hara
1997 Defender Wagon
Re-working 97 wagon
Still on interior . . .
Now that hinges are replaced, floors are stripped and repainted w/ stainless bolts and new carpets going in, among the many thousand things to do , One issue I know I will also want to repair is the rear door.
3 questions:
1- overall conditions of most panels is good, however, there is some bubbling/rust at the rear door bottom (latch side) Rust due to rain draining in via the handle? - has anyone cleaned this up before? POR-15? Clean/sand repaint? Treat inside?
2- The rear inner trim panel has a small tear (about 1"), which I assume is common, I had considered mounting somthing there perhaps I can find a 110 rear door pocket? (other suggestions?) or what replacement panel is most applicable? Can I find a replacement original at a reasonable cost?. I have seen the diamond plate ones online. Opinions re these?
3- Also planned to clean up rear hinges . . is someone making alloy ones for rear yet? If not best route in rust proofing existing ones?
Thanks!
Old October 15th, 2004, 04:15 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Originally Posted by Kimos
1-Clean/sand repaint? Treat inside?
2- The rear inner trim panel (...)I have seen the diamond plate ones online. Opinions re these?
I'd say
1)Yes
2)I had mine made out of a diamond alu sheet...I used the old one as a cardboard and have it pre-cutted.
40 Euros.
Only issue is when refitting the bits,diamond surface doesn't allow a neat fit,so I had to help a bit with a grinder...
It's a bit rough but it works.
If you have the chance and $ you could try and have it CNC made.
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old October 15th, 2004, 08:45 AM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Larry,
1. I've used POR 15 on other vehicles and even though I prepped the area well it still started to peel after a few years.
2. You can get the QT rear door liners (http://4x4ag.com/products_lr_qt_rear_door_liners.htm) for $158.
3. Don't know.
Hope this helps.
John C.
Old October 15th, 2004, 12:21 PM
COSteve
Steven Reed
93 Defender 110 - #107
Does the rear panel fit a NAS 110?
Does the QT Panel Alum rear panel fit a NAS 110?
Old October 15th, 2004, 12:57 PM
JohnC
Measure the rear door, from hinge line of the door to where wiper motor starts
If it's 250mm or 10" then YES it would fit.
If it's 300mm or 12" then NO it won't fit.
John C.
door, rear door
TD5 90 Rear 1/4 panel guards, Best manufacturer/seller? DiscoDino Defender Technical Discussions 2 January 30th, 2006 01:31 PM
97 D90 SW - Inner rear door panel Kimos Wanted 5 December 2nd, 2004 09:26 AM
Diamond plate rear panel protectors Burke For Sale - Parts 3 June 25th, 2004 01:07 PM
D90 Rear Quarter Panel leafsprung For Sale - Parts 4 November 25th, 2003 02:04 AM
