Rear Door Hinge Screws - Defender Source
Old October 11th, 2003, 10:27 AM
Rob
rob
1997 D90
can someone tell me what the groove is for in the rear door hinge screw (the one with the spring).....can i replace them with regular stainless screws??
Old October 12th, 2003, 06:46 AM
KeithElisa's Avatar
KeithElisa
Keith Parkin
The grove in the bolt is to keep the old school lock washer in place it has a tab in it that keeps it from rotating when you bend down the outer tab. You can put any bolt in just make sure you use some sort of lock nut.
Keith
door, rear door
rear roll cage, rear seat, soft top surfd90 Wanted 0 January 12th, 2005 02:59 PM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
