Rear door hinge bolts - Defender Source
Old August 20th, 2007, 11:48 AM
bjf's Avatar
bjf
barry f
94 ST #395
I want to replace the hing screws on my rear door. Not the bolts that hold the hinge to the door but the bolt that acts as a pin to hold the two pieces of the winge together. It is a bolt with a spriing on the inside. Do they make it in stainless and if so where can I get it?
Old August 20th, 2007, 12:07 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
call Gorge at Rovers Down South. he has a kit thats 6 bucks - http://roversdownsouth.com/images/de...ingeKitDef.jpg
http://roversdownsouth.com/defender.htm
Old August 20th, 2007, 01:07 PM
bjf's Avatar
bjf
barry f
94 ST #395
thanks will call
are those stainless?
Old July 13th, 2009, 08:50 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Barry, how did you solved this ?
I want to put a ss pin/bolt too.
- Charles Eames
Old July 13th, 2009, 09:52 AM
bjf's Avatar
bjf
barry f
94 ST #395
I didn't go stainless. I just got new bolts, bushings, nuts, from George. The new style ones use a torx bolt.
Old July 13th, 2009, 12:13 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
It's probably an m6 x ... , i don't seem to find the size.
Anyone ?
- Charles Eames
Old July 13th, 2009, 12:17 PM
bjf's Avatar
bjf
barry f
94 ST #395
Just order from george or rovers north. I think they are 6 bucks each with the bushing, spring and nut
Old July 13th, 2009, 08:01 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Got them from stealership, they are
m6 x 60.
Name:	rear door pin:screws.jpg
- Charles Eames
bolts, door, rear door
Rear Axle Flange bolts chrisvonc Wanted 2 May 26th, 2008 06:46 PM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
Rear Bumper bolts? Quimbola Defender Technical Discussions 2 July 16th, 2004 11:30 AM
