Rear Door Electrical problems, what first? - Defender Source
Old August 4th, 2007, 09:59 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
None of the electical things seem to work. Wiper, defogger, squirter, also having trouble with the dome light, works if I turn it on manually but not when I open and close the door. any Ideas?
Old August 4th, 2007, 11:37 PM
Id start with the connections with the buttons.
Old August 5th, 2007, 01:01 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Make sure you have the rear door closed when you are testing these things. I know the wiper won't work if the door is open. The light sounds like the door pin switch. The rear washer probably won't work with the door open either.
door, electrical, problems, rear door
97 SW rear door electical problems! Hammertime Defender Technical Discussions 1 September 4th, 2007 08:51 PM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
