Rear disc brake options - Defender Source
Old September 23rd, 2004, 12:14 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
What is available? Anyone here done it?
Old September 23rd, 2004, 12:19 PM
DO you have the Rover rear or Sals rear? THe Rover rears come with Discs on 90s, and I know you can get discs for the Sals, as Yousef has Discs on his.
Old September 23rd, 2004, 12:51 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Mike,
Yes it is the Rover Sals. The 90's did not come with a Sals did they?
Old September 23rd, 2004, 01:00 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Nope.
Jimmy Buffett
Old September 23rd, 2004, 01:08 PM
Talk to Keith at Rovertracks I bet he could set you up with a set.
Keith Kreutzer [keith at rovertracks.com]
Old September 23rd, 2004, 01:34 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Mike,
Thanks. I will do that.
Old September 23rd, 2004, 04:36 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
A friend just did a 110 rear disc conversion. It was a complete bolt-on using all standard LR parts. When you add it all up, it's quite pricey. I think the most economical option may be to get a used disc brake Salisbury axle from someone like RDS. If you want a built HD axle, then yeah, check out RoverTracks. Here's the parts my friend used:
1 FTC1725 Axle shaft LH
1 FTC1724 axle shaft RH
2 FTC4785 hub seal inner
2 FTC5241 washer key front axle
2 571752 drive flange gasket
10 BX110095M drive flange bolt
2 FTC3179 lock washer
4 RTC3429 hub bearing
2 FTC3649 stub axle gasket
2 RUC105200 drive flange
2 FTC942 hub assembly
2 FTC1740 stub axle
2 549473 circlip
10 FTC1368 bolt, rotor to hub
1 SMD100260 mudshield LH
1 SMT100270 mudshield, RH
2 FTC3846 rotor
1 SFP000280 brake pads
4 FTC3375 caliper bolt
1 ANR2779 brake pipe
1 NTC7964 brake pipe RH
2 FTC3306 caliper bracket
1 STC1268 caliper RH
1 STC1269 caliper LH
Old July 7th, 2006, 02:17 PM
Ryan,
Can you get your friend to give a report out on this conversion? Any issues since? How's performance changed, and local parts sourcing? this is a great list. I'll bet some of these parts can be sourced used, and some appear to be shared with Range Rover Classics.
Old July 7th, 2006, 03:24 PM
I wonder if you could do it using disco hubs and disco shafts? EDIT: those hubs are just standard rover ABS style hubs, I have them.
I have a brand new set of rear calipers if you need those.
It looks like you have to buy new shafts with flanges (assuming disco I ones do not fit), stub axles (spindles) and caliper brackets, everything else looks like it crosses with D90/disco/RRC parts commonly available used (some brake part numbers (like rotors) are different but I think they are basically the same)
Old July 7th, 2006, 03:28 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
call Keith he has the parts you will need. or knows wha is needed. I looked into it a while back
its not that bad the most expensive part I remember is the cals
Old July 7th, 2006, 03:44 PM
It is not going to affect performance. Drums and discs give the same performace when both are in good conditions (on these vehicles in the rear). The downside of drums is that usage in mud wears them fown faster.
Old July 7th, 2006, 03:52 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
The drums I have work great BUT you have to keep them adjusted. with that said the masters seem to leak frequently. ooh well they are cheap
i added vented rotors & cals to the front & she stops scary fast now
Old July 7th, 2006, 03:54 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
A UK company that do this kind of product:
www.zeus.co.uk
- Charles Eames
Old July 7th, 2006, 10:08 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Originally Posted by mkellgr
Ryan,
Mark,
The conversion was done for a customer so the guy I know doesn't have daily use of the truck. And the parts were all purchased new from the dealer so hence quite expensive. If you're able to track down used parts, it may start becoming cost-effective. It looks like Ron has some of the interchangeability figured out so that would help in finding used stuff.
I wish I knew how the rear discs affected performance, but I haven't heard anything. I don't think there's been any problems, but I don't know how much it's improved the braking. I'll know eventually as I'm getting a used disc Salisbury from the UK. However, I probably won't get it swapped over until the end of the year.
Ryan
Old July 7th, 2006, 10:38 PM
are the current 110's on sals or something else, seem like the last (newest 110) I recall was the CKD on RR "axles" perhaps I am wrong. Would it be hard to convert to what the new (er) 110s are using?
Old July 7th, 2006, 11:40 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
seems like most of the parts in that list are interchangeable with the D90 (except axle/CV) and are not mandatory for the swap if in good cond.. I would imagine the key parts for the swap would have to be the Caliper mounts, Calipers, rotors ,pads and brake lines. The rear calipers are cheaper than the front.. (single piston vs double piston). I wonder how the double piston (frt.) caliper would feel on the rear of the NAS..
Old July 8th, 2006, 09:02 PM
Current model 110s use Rover style rear axles. Since around 2004, I think.
Old July 9th, 2006, 04:29 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Scary, I think, is the word that would spring to mind
Mike Hammond
Old July 9th, 2006, 10:58 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Do your brakes suck that bad or what!
Old July 9th, 2006, 12:40 PM
I hear the rear drums work almost as well as discs on the 110. I'm interested in the maintenance benefits. I had a 79 Jeep CJ7 with front discs and rear drums, and the rear drums SUCKED for maintenance!
brake
Rear diff replacement options cgalpin Defender Technical Discussions 20 July 14th, 2007 01:21 AM
Tailgate, Tire Carrier, 3rd Brake light, rear bumper jabber For Sale - Parts 5 December 8th, 2005 02:10 AM
Rear brake caliper leak cgalpin Defender Technical Discussions 11 July 8th, 2005 11:56 AM
Disc braked rear Salisbury axle Shane@EVS For Sale - Parts 2 August 6th, 2004 05:59 PM
