Rear disc brake options - Page 2 - Defender Source
Old July 9th, 2006, 06:11 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I put the larger 110 front calipers on my early 90 and a Classic Range Rover axle complete with discs on the back. That set-up stops things fine, and maintenance is much easier. My 110 has rear drums but rarely gets off raoded and I've used 1 set of shoes in about 90,000 miles
Mike Hammond
Old July 9th, 2006, 07:08 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
[Do your brakes suck that bad or what!]
My brakes are pretty good all around. On the road most of the braking force is transmitted to the front. So double piston makes sense. Double pistons in the rear I don't think would make much difference on road. But did you ever get that feeling in your gut when you have to back down a steep incline? I have, and I was wondering if double piston calipers would make a difference when in that situation.
Old July 9th, 2006, 09:31 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
hand brake!
Old July 9th, 2006, 10:11 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
[Handbrake!]
yes! last resort back up , no modulation though..
Old July 10th, 2006, 11:48 AM
newfD90's Avatar
newfD90
Chance
93 NAS 110
I just had my 110 converted last week. HUGE difference. I love how this thing stops now. Granted, I had a leaking cylinder, so I used that as an excuse to change to disc. Even the Wife could tell a difference. Talk to Keith at RoverTracks. He hooked me up with the right parts list and brackets and the guys at Pikes Peak Rovers did the excellent work. Using a combination of used RRC and Disco I parts, it was cheaper than doing the Zeus kit.
Chance
Old July 10th, 2006, 12:31 PM
Chance,
Now that's good information. Sent Keith an email. Thanks. (you wouldnt' have that parts list, would you?)
Old July 10th, 2006, 02:37 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
I'm pretty sure this was the final list of parts (it morphed somewhat during the conversion). I'll double check, but meanwhile:
Pre-ABS RR Classic hubs (front or rear). '89 or older I think.
Factory OEM Salisbury Disc brake brackets from Rovers North with .100" machined off the caliper mounting surface
Rear calipers from either a Disco I or D90
Rear rotors from a Disco I or D90
Brake pipes from a Disco I
I opted for all used parts except for the the consumables (rotors, etc) and the brackets. Thanks again to Keith at RoverTracks and Eric at Pikes Peak Rovers!
Chance
Old July 10th, 2006, 03:23 PM
I have everything but the brackets. I will give it a shot.
Old July 10th, 2006, 03:34 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Switching the front of a NAS 110 from solid to vented rotors is a better benefit in my opinion (for braking reasons mentioned in the post). You can install D90 front rotors and calipers as a bolt on. The rears maek life easier, but you won't see too much improvement if you just do the rears (some, but don't expect miracles).
Email:
Old July 10th, 2006, 04:20 PM
so bottom line, do both front and rear upgrades. Sounds good. thanks all.
Does anybody have part #'s for the RR hubs and salisbury brackets that I can reference? The rest is easy-breezy to find, but dont' want to "F-up" those 2 pieces.
Old July 10th, 2006, 04:25 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Forgot that Keith mentioned the bolt-on upgrade to the fronts. I figure I'll do that when it's time for pads. Also forgot to put Disco I Dust Shields on the above list.
I'll check my receipt, but I don't think part numbers are on it.
Chance
Old July 10th, 2006, 04:49 PM
I have a couple of spare sets of RRC non-abs hubs if anyone is in need.
Ron
Old July 12th, 2006, 12:23 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Other than the new Disco I rotors, no part numbers.
Chance
Old July 14th, 2006, 12:27 AM
Tawayama's Avatar
Tawayama
Michael Slade
No Land Rovers
Michael Slade
www.tawayama.com
Old April 6th, 2008, 08:41 AM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
What's your thought on the D90 front calipers vs the stock 110 calipers? I will get new vented rotors either way but have a set of front D90 calipers; should I stick with the stock 110 calipers on there or swap the D90 ones?
Old April 6th, 2008, 04:31 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
When you guys are saying vented, you're not referring to cross-drilled, right.
Old April 6th, 2008, 04:50 PM
mikeslandrover
Mike Hammond
Hmm... and this just bolts straight onto the Salisbury rear axle.
What drive shafts do you use? The Salisbury ones?
And the drive flanges??
This sounds interesting, most of the parts are dead easy to come by over here, except for the brake brackets does anyone have a part number for those?
also found this link
http://forum.landrovernet.com/archiv...p/t-26591.html
and answered my own question I think
2 FTC3306 caliper bracket
Mike Hammond
Old April 7th, 2008, 10:07 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Correct.
Jimmy Buffett
Old April 7th, 2008, 10:29 AM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
I guess my question is does a 110 vented disc exist that is a direct bolt on replacement for the solid version. I'm guessing not since the vented disc is probably wider.
Old April 7th, 2008, 10:49 AM
Based on my inspection of a vented disc caliper versus a standard caliper the only difference is a metal spacer between the caliper halves. I dont know if rover sells the spacer, but I've seen them somewhere.
brake
Rear diff replacement options cgalpin Defender Technical Discussions 20 July 14th, 2007 01:21 AM
Tailgate, Tire Carrier, 3rd Brake light, rear bumper jabber For Sale - Parts 5 December 8th, 2005 02:10 AM
Rear brake caliper leak cgalpin Defender Technical Discussions 11 July 8th, 2005 11:56 AM
Disc braked rear Salisbury axle Shane@EVS For Sale - Parts 2 August 6th, 2004 05:59 PM
