Rear disc brake 110 - Defender Source
Old May 7th, 2006, 03:25 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Rear disc brake 110
My first Post...
I have done a search on this forum to know how to make my UK 110 (in Canada) go from rear drum brakes to rear disc brakes. From what I could pick up it is a complete axel swap but for witch one and for how much. Is there a Kit or is it a custom job.
Thanks all.
Pat
Old May 7th, 2006, 04:28 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Originally Posted by Retrofit
My first Post...
Thanks all.
Pat
Pat,
I have thought about this too but did not think a complete axle swap would be needed. I have seen some series trucks with disc conversions that just needed some grinding and welding to make it work, I woulddn;t think it would be much more than that for the 110.
Old May 7th, 2006, 06:18 PM
Chris V
Guest
Posts: n/a
Check With Zeus, I bought a front drum to disk conversion from them for my 101FC , Chances are good they make a conversion for the 110.
Old May 7th, 2006, 06:47 PM
mattdh's Avatar
mattdh
Matt Hurst
i think i remeber seeing a conversion kit on DAP's web site at one time
Old May 8th, 2006, 09:47 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
imho rrc stubs rt caliper bracket calipers rotors
Call Keith in June hes down under
Old May 8th, 2006, 11:00 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Zeus makes them. I'm planning on getting a kit at some point.
Doug W.
Old May 9th, 2006, 12:41 PM
smenzel's Avatar
smenzel
Sandro
1967 Series IIA
I believe there's a not-too-difficult way to use a rear Discovery axle to get disc brakes on your 110.
Old May 9th, 2006, 12:44 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
WTF would you do that! Put a pos d1 axle under a 110 so you can have disk brakes! WOW thats out there!
Old May 9th, 2006, 01:01 PM
Doug's Avatar
Doug
Doug Walker
Never, never give up the 110s Salisbury.
Old May 9th, 2006, 01:04 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I sorry about the last comment go for it & I will give 200$ for your Sals. I got a d1 I would be more than happy to trade axles!!!!!!!!!!!!!
Old May 9th, 2006, 01:49 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
A friend had recently converted a customer's 110 Salisbury to discs using all stock Land Rover parts. It was a total bolt-on. It was a rather long list of parts, and fairly expensive once you added everything up. But it can be done. I would also check with Keith at Rovertracks as I know he's done a lot of work with Salisburys.
Does anyone know what the Zeus kit costs? It'd be interesting to compare to the cost of the individual parts my friend bought through a dealer.
Old May 9th, 2006, 04:40 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
It is poss w/ LR stuff. Late mod had rear disk.
Keith is at obc
Old May 9th, 2006, 08:56 PM
headdamage's Avatar
headdamage
Andrew
exmod 90 2.5na and a 93/RRC 200tdi
Just so you know the Drum braked rear axle is a touch stronger than the disc version due to better wheel bearing spacing and more spline depth in the drive members.
Old May 10th, 2006, 11:56 AM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Zeus Kit Info
OK, talked to Zeus and there's good news and bad news. Good news is that the kit's cost is fairly reasonable, bad news is they don't ship to the US:
The code for the product is Z1302. The kit cost is 500.00 which includes taxes and carriage.
Unfortunately we do not ship to the USA due to the high liability insurance costs since 9/11.
Regards
Graham Beck
Manager
Zeus Engineering
+44 01392 438833
I've written them back and asked if they have a US Distributor. Meanwhile, anybody know of a way to get the kit in the US?
Chance
Old May 10th, 2006, 12:16 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
have it shipped to someone in the UK then ship it to you direct...
Legend in My Own Mind.
Old May 10th, 2006, 12:58 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Call Keith In A Few Weeks!!!!!!!!!!!!!!!!
Old May 10th, 2006, 02:26 PM
btate
Bryan Tate
d90
My salibury axle had disc brakes when I got it from George at RDS
Worked great for me
Old May 10th, 2006, 03:20 PM
The drums work fine, actually at least as good as discs. Unless you are doing a lot of mud no need to switch. I know it can be done with hubs/rotors/calipers off of a Disco I and calpier brackets off an transition 110 disc brake axle (there were some axles made with discs but without the caliper brakets molded into the housing), but I think you need new axle shafts too. No biggy if you are upgrading but otherwise serious cash.
Old May 11th, 2006, 02:32 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
My friend told me it cost about $2400 for all of the LR parts about a year ago. This included axle shafts. So while this is possible, it doesn't seem very cost effective.
If the Zeus kit goes for 500 GBP (~$900 USD), that sounds like a good deal. Probably a good idea though to first find out what is included in the kit.
I got lucky and latched onto kind of a one-off deal on a used disc Salisbury in the UK. Another friend has a container coming this way so that made it a reasonable purchase. As previously mentioned, Keith may have other options as well. Forgot he was Down Under for a few weeks - Thanks Peter.
Old May 11th, 2006, 02:36 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Also try George I talked to him a year ago about the same thing & his # was 1700 for a complete axle.
110, brake
Rear disc brake options kellymoe Defender Technical Discussions 44 April 9th, 2008 09:34 AM
NAS 110 Rear Bumper Reefminis Wanted 3 October 2nd, 2006 04:54 PM
110 top, 3-door solid sides, full rear door Method PHX For Sale - Parts 7 March 10th, 2006 04:07 PM
110 Rear Seat newfD90 Wanted 5 March 10th, 2006 12:22 PM
Rear brake caliper leak cgalpin Defender Technical Discussions 11 July 8th, 2005 11:56 AM
