rear differential gasket ?? - Defender Source
Old May 12th, 2005, 05:13 PM
jstrong98's Avatar
jstrong98
Jon Strong
Just took a look under the 90 to see what was hanging from the rear differential.......looks like rubber gasket material ?? It appears to have split on the bottom , and pieces were hanging down from both sides. Looks like its missing the entire bottom third now. I'm going to open up the fill plug and pray there is still lube in the diff. Any ideas what I need to do. How much of a PITA is it to replace it, looks as if the drive shaft must be removed to do it.
The gasket is on the inside of the diff where the drive shaft unit bolts on.
thanks
JS
Old May 12th, 2005, 05:31 PM
Well your lucky its the rear! Drain the diff, pull off the wheels, then pull the 6 bolts holding the axle shafts on out then pull the shafts out. Pull the driveshaft off the diff end and tie it up to the frame, then remove the bolts holding the diff on, be sure to remove the top bolts that hold the break lines in place and carefully push them out of the way first. After all the bolts are off go get a friend to help you drop the diff, I put a jack under the pinion and push the diff off of the studs, it weighs about 80lbs and under the truck it is hard to handle. then set the diff down but not on the ring gear, scrape off the old gasket and put a new one on and put her back together.
Old May 12th, 2005, 05:41 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Jon, is it leaking, It could just be the extra gasket material that was squeezed out when the diff was originally put on. It sometimes peels off.
Legend in My Own Mind.
Old May 12th, 2005, 08:29 PM
redrover
Guest
Posts: n/a
Jon, most people use a black silicon like material called RIGHT STUFF. When the differential is tightened against the axle housing, it squeezes the excess out. And this excess may be what you see. As suggested, check oil level. All you need to have is a half inch drive socket . If the oil level is fine , and you dont see a leak , you are fine . Good luck JP
Old May 12th, 2005, 10:07 PM
jstrong98's Avatar
jstrong98
Jon Strong
I'll check the level tomorrow AM. The piece of gasket that i found is about 3 " long and maybe 1/4" at the widest part. It looks like it could be excess gasket material.
I have not noticed any leaks, and I park the truck in the garage every night, so I should have seen some evidence of a leak.
Thanks for the quick replies.
JS
Old May 13th, 2005, 08:28 AM
just excess right stuff, don't worry.
Ron
differential, gas
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
Rattle From Rear Krna Defender Technical Discussions 3 July 26th, 2004 11:50 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
