rear diff switch-out - Defender Source
Old December 20th, 2006, 01:59 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I'm planning to switch out the third-member portion of my rear diff this weekend. Can someone let me know if I'm missing anything? My basic plan of attack is the following...
1. Drain Oil, remove rear wheels and remove rear driveshaft
2. unbolt and remove axle shafts (I'm assuming they unbolt and slide out with no special tools)
3. remove old third-member (again, assuming once the bolts are removed and axles are out the member basically drops free.
4. replace new third-member by bolting it back on.
5. replace axle shafts
6. refill with oil
Is there a gasket repalcement involved that I've not considered?
Clay
Old December 20th, 2006, 02:20 PM
94SW,4.6HSE,93LWB,83 110
Also need to remove the caliper bolts and the brake rotors. My brother and two friends did this entire job in about an hour and a half lying in the mud in the deluge @ MAR this year. None of them had ever tackled the job before.
Old December 20th, 2006, 02:28 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
You do not need to remove the brake calipers. After unbolting the drive members, just slide the axles out 6 inches to clear the diff. 3rd is mounted on studs not bolts, you will need to shimmy it forward off the studs and be ready to take the weight. You can use a new gasket or just rtv when installing the new one.
Old December 20th, 2006, 02:35 PM
1of40's Avatar
1of40
1of40
what's rtv?
Old December 20th, 2006, 02:41 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
gasket goop
Old December 20th, 2006, 02:47 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Try to get the gasket, I try to only use rtv if I have too.
x2 on not removing the calipers
Old December 20th, 2006, 02:49 PM
1of40's Avatar
1of40
1of40
got it. Bill at GBR says he uses permatex ultra black. If I can locate a gasket by the weekend I'll just do the goo.
Old December 20th, 2006, 03:16 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Just use the RTV, the factory does. They haven't put in diff gaskets, or drive flange gaskets for a few years now. Its all goop, and it works better than the gaskets in these applications.
Email:
Old December 20th, 2006, 03:22 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Just remember that the Diff is a 58lb lump so don't have your hand pinched when the old one comes free. I have spoke to many customers with sore hands after thier diff fell out on thier hand as they were fighting with it.
Good luck
Eric
Old December 20th, 2006, 03:34 PM
1of40's Avatar
1of40
1of40
Thanks. Very excited to get going on this this weekend.
Old December 20th, 2006, 03:56 PM
D90user's Avatar
D90user
steve
I was told by Bill @ GBR to use the paper seals at the hubs so that the play in the hub would be minimized. This was stated in reation to minimizing spline wear in the long term. Plus if you jsut spear them with grease you can often reuse them in a pinch.
Old December 20th, 2006, 04:12 PM
ECR's Avatar
ECR
A NAS D90 has one piece axle shafts. Theres no splines to wear or flex on the wheel side.
Email:
Old December 20th, 2006, 05:12 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
If that new lump is a locker you won't want/have the stock axles for long.
Old December 20th, 2006, 05:22 PM
D90user's Avatar
D90user
steve
good point...I was assuming HD 2 piece axles....
KevinNYIf that new lump is a locker you won't want/have the stock axles for long.
also a good point...
Old December 20th, 2006, 06:37 PM
Abrooks's Avatar
Abrooks
Tony Brooks
If I wasn't out of town this weekend, I'd offer for you to come over as I have the same project to undertake!
Tony
(soon to be locked!)
switch
Rear diff replacement options cgalpin Defender Technical Discussions 20 July 14th, 2007 01:21 AM
NAS 90 rear Diff whistler110 Defender Technical Discussions 27 February 3rd, 2005 03:04 PM
Stock diff, stock rear axle half shafts..... nilesj For Sale - Parts 5 October 15th, 2004 11:10 AM
rear diff and rear seatbelts for '94 D90 rover_rich_d90 Wanted 1 April 20th, 2004 08:54 PM
