Rear diff replacement options - Defender Source
Old July 16th, 2005, 12:56 PM
I broke by rear diff last weekend. Appears to have bene due to impact on the rear cover (yes i own a rear diff guard, but didn't have it on at the time ). I just don't learn
http://lhsw.com/gallery/reardiff
So what are my options, ranging from just replacing with used stock to to new/rebuilt stock to upgrading to an ARB locker and upgraded shafts?
Unless there are some really good deals out there, this might just be academic as I'm low on cash right now, but I'd like to see what everyone thinks.
I dont think I have the skills (without help) to rebuild it myself properly.
thanks
charles
Old July 16th, 2005, 03:23 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
That happened to ours about 6 years ago and it was a great time to replace it with an ARB. The ARB's are usually about the same price as all the stock parts anyway and you get it locked at the same time. No reason to not do it really, that's the way I see it at least. Or you could just buy this
http://www.defendersource.com/forum/...ead.php?t=5892 I would if I could right now.
Old July 16th, 2005, 04:38 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I saw this on ebay earlier today...
http://cgi.ebay.com/ebaymotors/ws/eB...PcY_BID_Stores
Rob
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old July 16th, 2005, 05:54 PM
Welcome to the club! I broke a few of them! Just throw a stocker in there for now unless you want to buy axles and a Detroit, or just an ARB and take it easy on the useage. GBR will be the best bang for the buck as far as a new diff with locker, then I would get some Rover tracks Axles, or just leave it stock and open for now.
Old July 16th, 2005, 06:57 PM
You should be able to buy a stock diff and R&P for $100 tops.
Old July 16th, 2005, 07:43 PM
Ron, are you saying the entire assembly, including the pinion etc like what's on ebay there?
Got any links? Thats right up my alley.
charles
Old July 16th, 2005, 07:54 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
You might also try Will Tillery in Richmond. He may have a couple assemblies laying around.
ROVERGUY PARTS 804.539.5845
Old July 17th, 2005, 04:31 AM
Not the housing, just the guts.
With housing figure 150-200
Old July 17th, 2005, 08:11 AM
scoloco's Avatar
scoloco
'94 D90 ST
Charles, do you need a housing also? Or just the diff?
Old July 17th, 2005, 12:21 PM
I just need the diff. My concern is how hard is it to *properly* install it and whether I am up for the job. Around here it would cost me more to have someone do the work than to get a complete unit, that I know.
I'll do some searching to see exactly whats involved.
charles
Old July 17th, 2005, 08:27 PM
scoloco's Avatar
scoloco
'94 D90 ST
Charles, if the diff is already setup, its a piece of cake to install. I've swaped the rear diff a couple times now. Getting it setup is something I would probably get a pro to do. If you go with GBR, they are all setup and ready to put in. YMMV.
If you can find a 4pin, thats the way to go esp in the rear. With a locker was only a bit more than the open 4pin carrier when I was looking around. Or do as Hippert said find a stocker cheap (for now).
Old July 19th, 2005, 12:35 AM
Thanks JB
Will has a low mileage complete stock assembly at a good price, so I'm going for that.
Thanks for the tips guys.
charles
Old July 10th, 2007, 10:42 PM
Shake
Bob Hanson AKA Two-Socks
Red 94 D-90 #428
Current Info. on Differential Options???
Hey folks,
Been a couple years since this was discussed. Is there a more current post that talks about ALL the stuff GBR sells now. Detroits are auto lock right? Need new axle too? Who has what in their defenders? Any failure of the air systemi n the ARBs? Anybody done a poll?
Thanks.
"I ain't lost!!, ain't NEVER been lost...<Scratching head>Been a might confused fur a few hours...but I ain't never been lost."
Old July 10th, 2007, 10:55 PM
94SW,4.6HSE,93LWB,83 110
Rear Diff
I have two 40k spares that I bought for this reason. I am going to be in Loudon County this weekend. I want the $150 I paid for one. If you are interested my cell is 410-200-4386. I think Will Tillery moved his operation down to South Boston- he's a great resource. I've bought a transmission and transfer case from him.
Old July 11th, 2007, 08:51 AM
Doug, if you are directing this at me, that was a year ago and I'm all set thanks. Shake is in CO. Will is in SC or SC afaik
Shake - stock diffs all the way. Cheap to replace. Would like ARB one day though.
hth
charles
Old July 11th, 2007, 06:51 PM
Do you get a little more capacity in the diffs with those pipe caps?
Old July 12th, 2007, 09:31 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I found GBR's website easy to read and understand. After I read what they had to say on their site a couple times I called Bill at GBR and talked shop. He says it like it is. I ended up deciding to have them build me a front and rear diff with a truetrac and detroit combo. Bill's advice was no upgrade of axles b/c i'm only running 33's. I've had no problems on the road or the trails. I think they're as tried and tested as much as anything else out there. If I was planning to run larger than 33's and going extreme I'd consider going ARB and upgrading axles and CV's, but honestly, I don't see the sense in going extreme in a defender. Makes more sense to me to do that in a dine-a-dozen jeep.
just my 2 cents.
Clay
Old July 12th, 2007, 11:52 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
just my 2 cents.
Clay
Yep,
Going extreme in a Defender is idiotic. Originality sucks.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 12th, 2007, 09:54 PM
Shake
Red 94 D-90 #428
Hey Buck,
You normally explain this stuff pretty well. I just don't get it. Hear stock is cheap but when I shop for new, they are close to the same price as ARBs. And then I guess they don't come with gears...Huh?
Seen mention of 411 gears to help with mountains. Don't the differentials come ready to install?
I don't want a rock crawler...Mostly daily driver and mountain trail access.
Old July 12th, 2007, 10:20 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Originally Posted by Shake
Hey Buck,
Ah man,
I was completely cool with just being a smart ass in this thread. PM me with exactly what you want, where you are now, and what tire size you are running and I can run down all your options starting with cheapest to best.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
ac
110 rear diff clunk D90user Defender Technical Discussions 14 November 19th, 2005 01:49 AM
rear diff cover cracked, replacement ? artm Defender Technical Discussions 4 September 9th, 2005 12:00 PM
Stock diff, stock rear axle half shafts..... nilesj For Sale - Parts 5 October 15th, 2004 11:10 AM
rear diff and rear seatbelts for '94 D90 rover_rich_d90 Wanted 1 April 20th, 2004 08:54 PM
