rear defroster indicator 95 D90 SW - Defender Source
Old February 1st, 2014, 07:22 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
Quick question on defroster illumination "warning light" on warning lights panel....
Is it supposed to light up when rear defroster switch is pushed? Because mine is not...
Have searched and ran across this exchange which is a bit confusing for moi...
the 3 switches (hazard, rear defrost and heated front screen) all light up green when the lights are on.
The hazard has a red bulb that flashes when the hazards are on.
the rear defrost warning is on the dash binnacle and that switch does not light up when pressed
the heated front screen has an amber bulb and will light up when pressed, but it is on a timer that is tied into the oil pressure so if you push it without the engine running it will only stay on for a few seconds
BTW the red bulb for the hazard is NLA, so don't loose it.
and...
The correct factory set up is that the rear defrost has no amber illumination in the switch, it just indicates on the dash. you can set things up any way you like though.
I believe the discussion was for a 110 with front defrost but it's not clear enough for me..
Thanks!
KCD
Old February 1st, 2014, 08:30 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Yes, the defrost illumination on the panel lights up on mine. The switch does have a bulb, but it doesn't light up on the switch - and do not see where it would illuminate from as the switch cap/face is solid.
Old February 1st, 2014, 08:34 PM
I've always wondered about that
Old February 1st, 2014, 08:58 PM
kevincdoyle
Kevin C. Doyle
Awesome and thanks, My next little project. (any clue where to start, feel free to chime in!)
As an aside, I got all of my dash lights, fan, air speed, wiper, washer, etc working and what I have noticed is that, in the dark, the defroster button gets a little bit brighter when I push it in. (that's what she said...) I figure it is just because it is a tiny bit closer to the bulb when "engaged".
KCD
Old February 1st, 2014, 10:14 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
I'll have to check it out in the dark, couldn't see it daylight when I replaced mine.
Old February 2nd, 2014, 02:12 PM
kevincdoyle
Kevin C. Doyle
Well, too much snow here to shuffle cars...
Anybody have any idea which fuse the rear defrost or warning panel light goes through? Looked in the owners manual, online and searched to no avail...
Thanks Board!!
90, 95, d90, defroster
Wanted: D90 SW Rear door PCRover Wanted 6 November 1st, 2007 01:16 PM
Rockware sliders and rear shock mounts for D90 Shane@EVS For Sale - Parts 4 March 23rd, 2006 12:45 AM
97 SW Rear Hoop Pix Yousef dnewman9 Defender Technical Discussions 4 July 20th, 2004 01:55 PM
FS: Four SW Jump Seats from 95 D90 DJ Menasco For Sale - Parts 4 December 19th, 2003 12:28 AM
