Rear Defroster dead- stumped. - Defender Source
Old November 9th, 2012, 03:26 PM
J.P.
Jens Petersen
1997 D90sw
It's the factory 1997 hardtop rear defogger with dash switch in center nacelle. Worked one week, now nothin.
Checked fuses, relay- ok. Dash switch is ok(swapped with squirter switch and nothing) and getting power to it. Dash indicator light is ok.
Checked with engine running.
Window and Element and connections seem ok.
Where could it be disconnected? if it is. Did not hear relay click since it crapped out.
Thanks.
Old November 10th, 2012, 05:17 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
That should be in the chassis loom. I would check the chassis loom connections on the firewall. I would also check the wires in the rubber cover at the rear door. Those wires get moved a bunch with the door opening and closing. I would also check the ground rear good.
Land Rover 110
defroster
Rear diff replacement options cgalpin Defender Technical Discussions 20 July 14th, 2007 01:21 AM
Rear Bench Seat + hardware Chaucer For Sale - Parts 8 September 29th, 2005 12:16 AM
rear roll cage, rear seat, soft top surfd90 Wanted 0 January 12th, 2005 02:59 PM
rear diff and rear seatbelts for '94 D90 rover_rich_d90 Wanted 1 April 20th, 2004 08:54 PM
