rear cross member replacement question - Defender Source
Old April 2nd, 2007, 09:13 PM
Cirbo's Avatar
Cirbo
Jim C.
Greetings all,
With all this talk about rear cross member replacement, I seem to remember someone talking about a solution to sourcing replacement fuel tank brackets. (those two brackets that the fuel tank skid and sway bar bolts to) I tried a search, but didn't come up with any luck. Can anyone assist?
TIA,
Jim
Old April 2nd, 2007, 09:29 PM
huck1974's Avatar
huck1974
shane cates
94 d90
I am new, but tell me if I am understanding. What exactly are you referring to as the sway bar mounts to the plate that holds the tank up and that plate is bolted to the steel that surrounds it. I made a new tank plate out of heavier steel and welded nuts on the back side for the sway bar. Am I way off base?
Old April 2nd, 2007, 09:33 PM
mattarm's Avatar
mattarm
Matt
1993 D110
I sourced a rear crossmember with extensions ($395.00) from Rovers North. PN: PLH619110
ID:	8884   Click image for larger version
Old April 2nd, 2007, 09:35 PM
huck1974's Avatar
huck1974
shane cates
94 d90
OK, gotcha now
Old April 2nd, 2007, 09:37 PM
Cirbo's Avatar
Cirbo
Jim C.
I'm talking about the two brackets that the plate bolts to. You can see them from the wheel wells. They have large holes that the poly tank can be seen through. There is one welded to the side of each frame rail.
Old April 2nd, 2007, 10:16 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Ok, large holes approx 4" wide by 3" high oval that shows where the tank plate and sway bar mounts?
I can't really see anything to be repaired or replaced that is bolt on except the plate under the tank itself. Sorry I couldn't help
Old April 3rd, 2007, 06:32 AM
pendy's Avatar
pendy
jim pendleton
89'd90
I made a couple of those for JimC some time back. I'm sure you could fab up a couple of them Cirbo.
JP
legend in my own mind
Old April 3rd, 2007, 08:50 AM
Cirbo's Avatar
Cirbo
Jim C.
Can do, but I was hoping to find the easy button and not have to re-invent the wheel.
Old April 3rd, 2007, 01:43 PM
I tried to find the easy button too, and it turned out to be Pendy. Incidentally, he did a great job replicating them and the bolt-on option has worked extremely well.
Old April 4th, 2007, 10:59 AM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
A little bit of a thread hijack but are these side plates/brackets all that I would need to mount a NAS style gas tank to a european frame?
CB
Old April 4th, 2007, 11:29 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
CB
That and you have to modify the rear crossmember a bit to allow for the tank (basically removing the sharp edge off the Euro crossmember).
We used to convert Euro Tdi frames to NAS/ Tdi all the time, its really easy and we have all the jigs if you need parts.
Email:
Old April 4th, 2007, 07:45 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Mikes your man. My cardboard template has grown wings by now.
JP
Old April 4th, 2007, 09:32 PM
Cirbo's Avatar
Cirbo
Jim C.
Mike x 2
I had to spend an hour with the plasma torch and grinder before I could even begin to think about fitting the crossmember (with extensions) on to the existing frame.
Old April 4th, 2007, 09:52 PM
huck1974's Avatar
huck1974
shane cates
94 d90
sorry again I couldn't help. We have a waterjet and about everything known to man involving metal. If I have a template, I can make anything for you guys. Glad you got it taken care of.
Old May 23rd, 2008, 02:03 PM
ollieskins's Avatar
ollieskins
Wade Garrett
1994 defender 90
That cross member with extensions looks nice. I will have to look into one of those.
Old May 25th, 2008, 10:42 AM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
it sure does, get it galvnized pronto!
Old May 25th, 2008, 01:04 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Photos
Anyone have any photos of the crossmember installed?
ac
90/110 replacement rear cross member Tyler Wirken For Sale - Parts 8 November 21st, 2008 09:17 AM
Rear diff replacement options cgalpin Defender Technical Discussions 20 July 14th, 2007 01:21 AM
rear cross member 1of40 Defender Technical Discussions 5 December 1st, 2005 11:48 AM
New Safari Gard 3-link cross member Davis For Sale - Parts 2 July 4th, 2004 05:00 AM
