Rear clunk 1985 110 - Defender Source
Old November 15th, 2015, 05:44 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Rear clunk 1985 110
Yesterday while driving home I turned slowly into the neighborhood and got a clunking sound which came from the rear. The sound continues now in more slower speed / turning / or light acceleration or deceleration situations.
So far I have found the self leveler unit had a small leak so I removed it. The clunk continues. Found sway bar ends were loose, tightened and no change. Inspected wheel bearing / axle play and nothing significant. All mechanicals are full / greased. Any ideas?
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
1971 109 3 Door (Sold)
Old November 15th, 2015, 05:56 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Rear A frame ball joint
Old November 15th, 2015, 05:57 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
What I was thinking. What is the best check?
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old November 15th, 2015, 06:45 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
You could get a pry bar in there and see if there is play in the joint
Old November 15th, 2015, 06:50 PM
that or axle flanges
Old November 15th, 2015, 07:17 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
I have a video capturing the noise. Can't figure out how to post it yet. The clunk / pop appears center line on the truck. Checked all drive shaft bolts.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old November 15th, 2015, 07:19 PM
Start with wheel nuts...
Ask me how I know....
Old November 15th, 2015, 07:26 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Originally Posted by Rocky View Post
Start with wheel nuts... Ask me how I know....
Checked those.
------ Follow up post added November 15th, 2015 07:29 PM ------
Anybody wants the video I will text it to you
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old November 15th, 2015, 08:03 PM
tijnes
Martijn
110
The handbrake mechanism that's sticking can cause clunking at low speeds too.
Old November 15th, 2015, 08:04 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Might remove the rear drive shaft to see if it goes away and more thoroughly check the UJ's.
Old November 15th, 2015, 08:18 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Might work on that after kids are in bed.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old November 16th, 2015, 09:20 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Crack up at the flange on the long shaft side. Not the complete problem though.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Went through the brake. Not sticking.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old November 16th, 2015, 09:39 PM
if the wheel flanges are striping out the bang still comes from the center as the slack gets taken up. Took a short ride in one of my brothers 110's and asked him if the drive train bang didn't bother him- he came up to the shop scrounging wheel flanges a couple days later.
Easy to check, no need to pull anything apart, jack up one side of the axle-leaving the opposite tire on the ground, pull the grease cap and rotate the tire and watch the splines of the axle in the flange. I have seen trucks where you could rotate the tire a 1/4 revolution. Check both sides that way
Old November 16th, 2015, 09:44 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
So I drove with the rear axle shafts out (drive shaft in) and am still getting a lesser of pop but with the same reverberation. I am thinking maybe the rear diff. (Salisbury)
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old November 16th, 2015, 09:47 PM
Is your truck lifted ? Have you removed the rear prop shaft ? I have had shafts where the u joints were fine but the splined slide was shot and wobbling. Not saying it isn't your dana 60 but that's a damn tough diff and you really have to neglect one for a really long time to hurt it.
Old November 16th, 2015, 09:55 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
The truck has a 2" medium TF coils. The prop shaft felt normal while attached. I will pull the shaft after work tomorrow.
------ Follow up post added November 16th, 2015 09:57 PM ------
I have the clunk recorded.. Just need to post the video somehow.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Rear end clunk? Burke Defender Technical Discussions 25 January 12th, 2014 01:28 PM
95 RRC rear axle clunk Surfin' Elvis Defender Technical Discussions 1 August 14th, 2012 07:51 PM
Clunk Clunk Clunk front wheel bjf Defender Technical Discussions 20 October 15th, 2009 01:19 PM
110 rear diff clunk D90user Defender Technical Discussions 14 November 19th, 2005 01:49 AM
