Rear Caliper tab broken - Defender Source
Old November 6th, 2009, 10:30 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I'm just about ready to put my new Disco axle in my truck and I noticed one of the tabs on the caliper that the cotter pins go through to hold the pads in is broken, do you need both to secure the pads? I was thinking yes, but was hoping I could still use it.
Old November 6th, 2009, 10:49 AM
budz
sal gorriceta
various rovers
Tom,
If you need calipers, call me at 9179070518.
Sal
Old November 6th, 2009, 11:15 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I'd guess you ideally need both. On the other hand I expect there isn't a lot of stress on them, so if it were mine I'd probably just weld or braze on some "meat" and drill a hole in it.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 6th, 2009, 11:48 AM
Used Di calipers are cheap, having brakes fail is not, that being said, I would JB weld and drill if it were mine. Weld I would worry about over heating the seals in the caliper.
Old November 6th, 2009, 12:03 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Gotta Love this site! No where else do you get this kind of service!
Sal has got a set for me.
Old November 6th, 2009, 02:08 PM
purely academic at this point but that far away from the seals on such a big chunk of iron the heat should not be a problem. worst case take the seals out.
I have heated up brake cylinders to get the bleed screws out though I usually pull the cups first. The welding heat will be much more localized than the heat from the big dumb MAPP torch.
That said, I have spares on the shelf and would use those before attempting any welding heroics.
Old November 6th, 2009, 08:19 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
especially JB weld heroics.....even a certified JB welder wouldn't fawk with brakes
Matt Browne
Old November 6th, 2009, 10:40 PM
I have driven home, on separate occasions, with a stick jammed in and clamped down with a hose clamp on a broken brake line and a set of vice grips on a broken brake line.
Old November 7th, 2009, 09:51 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Yeah, if one had a spare that would be the best option. But welding or brazing would work in a pinch. Brazing probably the best since you'd have to use nickel rod on a cast iron housing.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 7th, 2009, 08:47 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
I've always aspired to be more Ron like, but instead I've ended up carrying spare flex lines and parts to fix hard pipe........not sure where I went wrong.....there is no adventure in being prepared
Matt Browne
Rear brake caliper leak cgalpin Defender Technical Discussions 11 July 8th, 2005 11:56 AM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
