Rear bumper or not? - Page 3 - Defender Source
Old May 14th, 2010, 08:01 PM
LOL. It might have been in low range but I know for a fact the lockers were off, because when she started I directed her to turn them on, and she turned them off FU big man. But I'm glad you can drive better than a teenage girl
Old May 14th, 2010, 10:21 PM
Rugbier's Avatar
Rugbier
Gustavo
I love you 2 man
NO SIGNATURE
Old May 17th, 2010, 02:05 PM
Gardner's Avatar
Gardner
Gardner Congdon
'84 RHD D90 300Tdi
hitch
I like that receiver hitch- where's that from?
Originally Posted by Manimal View Post
Here's mine. Looking to get bumperettes installed.
Old May 17th, 2010, 02:42 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Charles I want to say it was my fault about the lockers you asked if the locker switches where down I thought they where.
She is a good driver just needs more time behind the wheel and maybe get a better driving boots
As for the hole itself everybody knows that the hole in the morning isnt the same hole at the end of the day.
all the holes , i called them the 3 amigos’ had been beaten up by the end of the day.
some big trucks with big wheels just dug them up.
Old May 17th, 2010, 05:32 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I'm not sure. Previous owner installed it. Does anyone on here know?
Old May 17th, 2010, 07:10 PM
rovertrader's Avatar
rovertrader
Dale
no bumper, with corner guards, and zero body damage... Paragon a few years back
ID:	27709   Click image for larger version
Old May 17th, 2010, 07:12 PM
I miss Paragon
Old May 17th, 2010, 08:19 PM
damn-that mudhole got brought up again ?
Old May 17th, 2010, 08:33 PM
Sal put the LWB into a nosedive into that one. Did not make it through and the airdam got a bit messed up.
Old May 17th, 2010, 09:01 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Thanks for the replies and the pics.
I ended up putting the rear bumper back on. Houston is the rear ending capitol of the world. I would rather they slide into a ball hitch that nothing at all.
Old May 17th, 2010, 09:05 PM
I had actually heard Barry's house is the rear-ending Capitol of the world.
Old May 18th, 2010, 12:45 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I like what I did with my bumper ends. More sliders than bumperettes. 1/4" steel, but if I were to do over, I think I would change everything to 3/16 (all my sliders/bumpers are 1/4" thick--I think that is a bit of wasted weight). I also ran 1/4" steel all the way from side to side over the rear cross member and mounted a dixon/bates to it as well.
Name:	slider mock up.jpg
ID:	27712   Click image for larger version
ID:	27714   Click image for larger version
ID:	27716   Click image for larger version
Name:	rear tire carrier.JPG
Old May 18th, 2010, 12:55 AM
CDN90's Avatar
CDN90
Tim
94 / D90 #79
Very Nice Chris - I was just thinking of something like this when the thread began...very clean!
Old May 18th, 2010, 08:58 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
This is not a bad idea at all !
Be prepaired to be emulated...
- Charles Eames
Old May 18th, 2010, 09:22 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Kudos Chris, that is very clean.
If you are worried about being rear ended, just drive around with a pintle hitch on the back.
Old May 18th, 2010, 09:32 AM
I like the bumperettes (and agree 3/16 would be fine) but I'm not a fan of the plate across the back. After having seen how the nas bumper traps dirt and causes the cross member to deteriorate I'd be concerned the plate would do that but 10x worse.
Old May 18th, 2010, 10:00 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I hear your concerns about the plate and corrosion, but the chassis was coated with PPG DP90 primer and then 2part epoxy paint and I am in Colorado plus the rear chassis corroding is typically a factor of the wheels spitting dirt/mud into the recesses on the other side of the chassis from the plate. I did the plate mainly for the Dixon/Bates to additionally distribute load (and the sliders and rear tire carrier)--probably overkill and I keep my eye one rust. Good concern, though.
For those that want to "emulate" (I am flattered) the sliders, the way I did it was to take foamcore board and make templates right on the bumper and then use these as templates for the steel. I then put the steel templates right on the corners of the truck and tack welded them in-situ to make sure the fit right then welded them all up. Took 1 day for both. I really like them a lot--they were really fun to make and I think are one of the coolest add-on's I have done.
One more thing--I trimmed the rear body panel to fit these. I also added a run of 3/8" or so square steel to the very top outside edge of the slider to finish off the seam between the slider and the body panel. I did this after the fact as I didn't like the body panel "flopping" around--I wanted it to look cleaner.
Old May 18th, 2010, 02:44 PM
texmoto
david summers
99 Discovery II
Sorry to hijack, but I really like the tire carrier as well. Did you fab it as well? If so would you post some more pics of it as well. Thanks.
Old May 18th, 2010, 02:48 PM
draaronr's Avatar
draaronr
Here
LR3
I think you could say that about holes in general
Old May 18th, 2010, 03:10 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Here is an older post on the rear tire carrier: http://www.defendersource.com/forum/...ight=Rear+tire
bumper
Removing Rear Step Bumper TurkD90 Defender Technical Discussions 16 July 20th, 2008 09:42 PM
soft top, rear bench seat, rear bumper AND alloys(trade) DBZ2009 For Sale - Parts 20 September 10th, 2006 09:00 PM
Disco Axle, Tire Cover, D-90 top, D-90 rear seat, Safari Gard Bumper m016324 For Sale - Parts 17 January 4th, 2006 09:20 AM
FS Front Wrap Around BBar, Bumper and Rear Bumper Mike M For Sale - Parts 6 November 18th, 2004 08:00 PM
