Rear brakes(?) squeak under load - Defender Source
Old June 24th, 2007, 11:31 PM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
I had noticed a while back that when reversing uphill (like my driveway) the rear would squeak just a bit. It also seemed that backing up, I would hear it more often. I never heard anything squeak if the truck was moving forward.
Once it reached the point of annoying, I did a rear brake install, cleaned everything and reassembled it. Everything has been working great, no noise or anything for about 200 miles or so.
I went and picked up a trailer this weekend. When the trailer is on, the rear brakes squeak a lot whenever the brakes are applied. It seems strange that load would cause the brakes to react this way. The trailer is small and had nothing in it, so I can't imagine the load was that much.
I tried searching around but couldn't find anything like this, so I thought I would toss it out here and see if anyone has seen anything like this?
thanks,
Bill Lewis
Bill
Old June 25th, 2007, 12:08 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Do you have the stock rotors or the vented/cross-drilled gimmick?
Old June 25th, 2007, 12:17 PM
kolvedic's Avatar
kolvedic
Bill Lewis
Yeah, I guess I should have mentioned that I have the stock set up for brakes. I just replaced the pads with the Lockheed replacements. I didn't replace the rotors because they both looked pretty good. I do have the HD OME springs on the back which have been on for a few years now.
I have tried to replicate the sound before by applying manual pressure to get it to make any sound to see if I could see where it is coming from but could not get it to do it by hand, so it must take some decent pressure to make it happen.
Bill
Bill
Old June 25th, 2007, 03:17 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
brake squeak normal....
My brakes tend to have a slight squeal. The local Land Rover dealer service department told me that slight brake squeal is completely normal. By the way, the factory-spec pads do NOT have squeal pads, so you won't know when the brakes are about to go....
brake
weak rear brakes? redrover Defender Technical Discussions 12 April 28th, 2006 09:24 AM
looking for SW rear load space mat NASD90 Wanted 1 December 13th, 2004 04:51 PM
ST rear load space matt in SW? Seriesman Defender Technical Discussions 6 November 2nd, 2004 12:44 AM
Need rear brakes...DIY?? P1CR Defender Technical Discussions 17 March 6th, 2004 03:46 AM
