Rear brake line set up - Defender Source
Old October 22nd, 2015, 11:27 PM
bossman429's Avatar
bossman429
Adrian
1988 90
I'm swapping a disco rear into my 109 coil sprung build. The disco has two brake lines going to the master cylinder I'm assuming for ABS. I don't plan on having ABS on my truck obviously so should I just replace the double elbow connector with a standard 2-1 tee? Most masters have a single rear and single front output no?
Old October 22nd, 2015, 11:31 PM
Sure. Single line with a tee on the axle.
Old October 22nd, 2015, 11:35 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Happen to know the thread size for the fittings?
Old October 23rd, 2015, 12:13 AM
Normally M10x1 with DIN bubble flares.
New NAS 90 Fuel Line Hoses (Line to Tank) FS SafariHP The Vendors Loft 0 August 28th, 2015 09:36 PM
Front brake line - why hard line & flex line? jefhuf Defender Technical Discussions 5 January 13th, 2012 09:03 AM
Quick question, let's say you lose the rear brake line on a D90, is it dual circuit? evilfij Defender Technical Discussions 8 July 21st, 2009 08:05 AM
Rear Brake Line 1of40 Wanted 1 January 3rd, 2008 01:49 PM
Line Lock for Winch Line Maine 110 The Vendors Loft 6 February 7th, 2006 06:47 AM
