Rear brake leaking? - Defender Source
Old March 14th, 2010, 05:35 PM
bjf's Avatar
bjf
barry f
94 ST #395
Rear brake leaking?
Was under my truck today and noticed one of my rear wheels is leaking. It isnt coming from the brake line fitting, It looks like it is leaking from the drum.
Thoughts?
http://www.flickr.com/photos/barryrides/4433473070/
Old March 14th, 2010, 07:23 PM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
Sounds like your wheel cylinder is leaking. Could need new rubbers or the whole cylinder could be shot. They're cheap to buy.
Old March 14th, 2010, 07:47 PM
bjf's Avatar
bjf
barry f
94 ST #395
easy to do? do i need to rush out and do it?
Old March 14th, 2010, 08:20 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Hey Barry,
I did this on my 110. I do not think it is too much different on the 90. I ended up replacing with a new cylinder. Fairly cheap. Hardest part for me was getting the springs to line up correctly. If you notice any difference in stopping, I wouldn't even risk it. See this for step by step info:
http://forums.lr4x4.com/index.php?showtopic=33909
MUDSUX
Old March 14th, 2010, 08:26 PM
bjf's Avatar
bjf
barry f
94 ST #395
This is on the 110. So annoying. Brakes still feel ok though
------ Follow up post added March 14th, 2010 05:30 PM ------
Looked at thread. Not sure I want to deal with bleeding brakes. Wonder what it would cost at a shop.
Old March 14th, 2010, 09:02 PM
isleofbones
Mike Deery
1984 D-90
Barry-
Don't despair... If it is a wheel cylinder, it is a very easy and fairly quick fix. It isn't worth having a cylinder rebuilt if it is original... they are so reasonable. There are easy step by step directions in any of the manuals... even the cheap after market manuals. I do disagree with Forrest about lining up the springs... It is really easy to eyeball and just pull the shoes into position, copying the pix in any of the manuals. There are probably some sites online with great instructions... Just google.
Good Luck.
Old March 14th, 2010, 09:07 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Drum brakes are drum brakes. Its all the same pretty much the same no matter the kind of car. Not a hard fix and bleeding brakes is real easy. Don't do something silly like press the brake pedal before the drum is back together.
And hay
And I love you too
Old March 14th, 2010, 09:21 PM
Barry, bleeding the brakes is easy, you can do it no problem. But make sure it's brake fluid and not gear oil you are seeing.
Old March 14th, 2010, 10:36 PM
bjf's Avatar
bjf
barry f
94 ST #395
ha yeah. Where should I get cylinder?
Should I just assume it is that?
Old March 14th, 2010, 10:42 PM
huck1974's Avatar
huck1974
shane cates
94 d90
take it apart and see. Ten minutes to know.
And hay
And I love you too
Old March 14th, 2010, 10:43 PM
bjf's Avatar
bjf
barry f
94 ST #395
true but if i take it apart then i have to fix it. cant put it back together screwed up
Old March 14th, 2010, 10:52 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Its ok to take things apart that are quick and easy and then put them back together while waiting on parts to come. This job is not hard. Don't sell yourself short. If you were close, I would do it for you. Jump in there and save some money on an easy project. 6 beers tops and your done.
And hay
And I love you too
Old March 14th, 2010, 11:02 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
This is the kind of thing i like to do in pair. Change both
cylinder at the same time and bleed until you get fresh
fluid in them.
- Charles Eames
bjf's Avatar
bjf
barry f
94 ST #395
Thanks man. Will pull the wheel and see what is going on.
Old March 14th, 2010, 11:27 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Originally Posted by isleofbones View Post
..... I do disagree with Forrest about lining up the springs... It is really easy to eyeball and just pull the shoes into position
Barry,
I totally agree with Mike about disagreeing with me. Don't let me discourage you about the springs. When I did mine I also changed out the brake pads so I took everything apart. It's the 2 springs that clamp the 2 pads together that I was talking about. By the way, my 110 didn't have the round shoe retainer seen in that link I sent you. Maybe yours is different. Changing out the wheel cylinder is easy though.
MUDSUX
Old March 15th, 2010, 10:57 AM
Convert to discs rather than dump more money into the drums.
Old March 15th, 2010, 02:31 PM
bjf's Avatar
bjf
barry f
94 ST #395
wont converting be more expensive? RN sells a kit to convert with axles and what not for 2100
Old March 15th, 2010, 02:34 PM
rip off.
Buy a set of new axles from lucky8 for $400, two brackets from George for $100 each and then find a used rear axle from an ABS truck and take the crap off of that an put it on your truck.
You can save the cost of the rear axles by machineing the brackets a bit as Keith does and using Non-ABS hubs.
Old March 15th, 2010, 02:35 PM
bjf's Avatar
bjf
barry f
94 ST #395
what do the brackets do?
What type of truck to get the abs parts from?
Old March 15th, 2010, 02:36 PM
Brackets mount the calipers. Anything with ABS. 1990ish on up RRC or any DI or D90.
From Crazy George
Genuine Land Rover
110 Rear Caliper Bracket
FTC3306 $100.00
brake
Tailgate, Tire Carrier, 3rd Brake light, rear bumper jabber For Sale - Parts 5 December 8th, 2005 02:10 AM
Rear brake caliper leak cgalpin Defender Technical Discussions 11 July 8th, 2005 11:56 AM
Left rear brake Light Out, and I mean Out! RickM Defender Technical Discussions 6 December 8th, 2004 09:31 PM
D-90 rear drum brake axle assembly TDI Guy For Sale - Parts 0 November 6th, 2003 04:59 PM
