Rear brake caliper stuck / won't bleed - Defender Source
Old March 16th, 2012, 05:58 PM
Using a Motive Black Label European Bleeder. Just got done bleeding the clutch, went no problem.
Moved on to the brakes, the F-driver / F-passenger / R-driver calipers all bled fine, but when I got to the R-passenger one I cracked the bleeder and...nothing. Obviously stuck caliper, but is there anything that can be done (i.e. putting suction on it) to kick off the bleeding? Or is my only option remove & replace the caliper?
It's also worth noting that you may want to put a little PB Blaster on the bleeder nipples before starting if it's been awhile, mine were stuck pretty bad.
Old March 16th, 2012, 07:34 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Not much help, but the calipers are easy to rebuild.
Semper Fi!
Old March 16th, 2012, 07:42 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
There were some smoking deals on rockauto on reman ones. I just replaced all my calipers because of 2 stuck pots.
Old March 16th, 2012, 08:25 PM
False alarm...it was actually just the bleeder nipple was clogged. Of course I made a mess when I pulled it out to clean it, so had to pull apart the pads/rotors and clean them off but I'm back in business.
bleed, brake
FS 3rd brake light and rear tire carrier Broncoduecer For Sale - Parts 11 August 23rd, 2011 05:42 PM
Rear disc brake options kellymoe Defender Technical Discussions 44 April 9th, 2008 09:34 AM
Range Rover Front Brake Caliper Question TDI Guy Misc. Chit-Chat 10 May 24th, 2006 08:14 PM
Clogged brake lines? Heath Defender Technical Discussions 11 February 24th, 2006 08:39 AM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
