Replacing the rear suspension ball joint.
Removed the two bolts. My understanding is the ball joint should just lift out...I have beaten it pretty hard. Some heat. Hasn't budged.
About to go cherry hot. Typical to rust in place?
Can it be pressed out from the "top" ?(pictures look like the hole is a through hole). Was thinking of cutting off the ears that the bolts hold down so I have the ability to perch it on the bracket and press it out.
Also, the swivel for the Boge unit. It just threads out - lefty, loosey yes?
thanks
thanks
