rear ball joint - Defender Source
Old October 11th, 2003, 01:49 PM
mattdh's Avatar
mattdh
Matt Hurst
rear ball joint
has any one replaced the rear ball joint to the top link? had the old one pressed out already and new one pressed in. the ball joint is tough to move around in its socket, is this okay or was it damaged when i had it pressed in?how would i torque set this nut?
Old October 11th, 2003, 03:59 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
It should not be tough to move.. It should move freely. How was it pressed back in? Did they use a big socket to go on the outer flange so no pressure was on the actual joint? I did mine liket htat with no prob.
Old October 11th, 2003, 04:43 PM
mattdh's Avatar
mattdh
Matt Hurst
im not sure how they did, it but i had to use a mallet to move it the first time and know its moving a little more freely
Old October 13th, 2003, 04:28 PM
mattdh's Avatar
mattdh
Matt Hurst
randy (or anyone) would you have the torque specs to all the related bolts on the rear top link(1.top bracket to chassis 2.bushings to top bracket 3. toplink arms to ball joint 4.two little screws to ball joint 5. ball joint to axle) thanks
Rear A-arm Ball Joint ?'s Monkeyboy Defender Technical Discussions 11 November 6th, 2006 01:20 PM
Rear Ball Joint Buckon37s Wanted 4 April 9th, 2006 06:54 PM
A-Arm Ball Joint Replacement RyanS Defender Technical Discussions 5 June 11th, 2004 11:32 AM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
