Rear axle tube swap - Defender Source
Old March 26th, 2011, 07:46 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Rear axle tube swap
Swapping in a new rear axle tube for the one that broke. I think this one came off of a Disco or RRC. It has a little tube that goes through the outer flanges; is this for an ABS sensor?
I want to use the stub axles off of my old D90 axle and I'm pretty sure that they don't have holes for these tubes. Can I just grind these little tubes down and use my D90 stub axles?
Any other incompatibilities between the various rear axle tubes? These tubes are marked FTC3324.
Old March 26th, 2011, 08:10 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Yep that for ABS sensors. It has to go or you need a set of ABS stub axles with the notch for it.
Old March 26th, 2011, 10:13 PM
chris snell
Chris Snell
87 Ex-MOD 110
Thanks, Kevin. I'll grind those little ports off.
axle
GBR HD rear axle shafts with drive flanges crown14 For Sale - Parts 1 February 9th, 2011 07:36 PM
series rear axle housing orionpco Series Technical Discussions 7 October 27th, 2010 11:04 AM
D-90 transfer case & rear axle Departing90 For Sale - Parts 10 August 9th, 2009 01:28 AM
NAS 110 Salibury rear axle for sale ECR For Sale - Parts 8 May 22nd, 2006 07:59 AM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
