rear axle swap - Page 2 - Defender Source
Old March 27th, 2015, 07:54 PM
jason1st
Jason Crandall
2006 LR3 2012 SC 1983 110
I rebuilt my salisbury and added rear discs. Easy. Parts were easy to find.
Old March 27th, 2015, 09:03 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Originally Posted by Red90 View Post
A plow that does not bend or break.....
(I'm trying to imagine that French accent...)
You've never seen a broken Sals??
Rent my
Old March 27th, 2015, 09:05 PM
skeenaskater's Avatar
skeenaskater
Jaap Kalkman
1997 Defender 110
Thanks guys! I think I will get the Ashcroft 3rd member with a locker. I believe they can do that with a 4 pin instead of a 2 pin. It's pricy but I plan to look after this truck and drive it for the rest of my life. Do some upgrades along the way... I'll have to check what the best place is to get that from here in BC. Cheers. and many thanks for the help!
Old March 27th, 2015, 09:19 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
I have a built stock diff w 354s in Vancouver for a 97 d90 ... And stock axles as we'll if you want to go for a cheaper option...
Old March 27th, 2015, 10:00 PM
Oui, it dues not breke.
Old March 27th, 2015, 10:02 PM
There's no such thing as a 2-pin ashcroft locker, so you'd better be getting a 4 pin for your money!
Old March 27th, 2015, 11:14 PM
all someone has to do to see one break is follow me @ The Cove.
Old March 27th, 2015, 11:23 PM
(I'm trying to imagine that French accent...) You've never seen a broken Sals?? .
The half shafts yes but those are simple to upgrade. The center is way stronger than 24 spline.
Old March 28th, 2015, 09:05 AM
skeenaskater
Jaap Kalkman
1997 Defender 110
Mine is a 110. I believe that would not fit? And could you explain to me what 354's are?
Old March 28th, 2015, 09:32 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Yours is no longer a "110" axle in the conventional terms, you have a 90 axle, perhaps with 90 or 110 spring seats, who knows.
Mark's diff would install easily. 3.54 is the gear ratio on the 3rd member
Old March 28th, 2015, 09:42 AM
skeenaskater
Jaap Kalkman
1997 Defender 110
Thanks Zack. I understand now. That sounds like it would fit. Mark: mine is 24 spline; is yours 10 or 24? In order to install it would I need any other parts? Seals? etc.
Old March 28th, 2015, 10:36 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97s were all 24 spline. I'm not sure which seals you would need.
Old March 28th, 2015, 10:52 AM
http://www.defendersource.com/forum/...all-58866.html
some edits based on comments from other folks:
use RTC3511G for the hub seals and RFD10000 for the hub nuts
Old March 28th, 2015, 12:43 PM
skeenaskater
Jaap Kalkman
1997 Defender 110
Thanks guys, that helps a lot. I'm getting Mark's old diffs. for now. That way I have some money for other upgrades I need to do and I can do the locker at a later date.
Old March 28th, 2015, 01:07 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Check your propshaft length as well… For example: Sals are a bit longer in the nose and thus slightly shorter rear propshaft.
Old March 28th, 2015, 02:24 PM
skeenaskater
Jaap Kalkman
1997 Defender 110
Thanks, yes, should be ok because mine was not a Salisbury but a Rover axle. So should be a simple swap :-)
axle
Pics of HD rear axle vs stock axle? josh-man Defender Technical Discussions 22 July 4th, 2017 04:22 AM
Rear Disco axle swap bossman429 Truck Build-up's & Restores 21 September 11th, 2012 09:16 AM
1997 D-90 rear axle housing and 83' 110 front axle housing Tyler Wirken For Sale - Parts 0 January 3rd, 2012 06:31 PM
Rear axle tube swap chris snell Defender Technical Discussions 2 March 26th, 2011 10:13 PM
Series III Rear Axle (Drum-to-Drum or Axle Housing) Lriwater Wanted 0 September 7th, 2009 08:08 PM
