Rear axle defender 90 vs 110 - Defender Source
Old May 20th, 2014, 06:43 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
Does anyone know if the 110 24 spline Salisbury rear axels can be used on a D90 with hd flanges and rover 24spline diff? The part # are FTC1724 and 1725.
The 90 rears with the attached flanges measure 26.25" and 36.75" total lengths including flange.
One site in the uk had dimensions on the 1724&1725 as 25" and 37.6". Seems like to me the diffs aren't centered the same but there is mention of narrow flanges which may make up the difference?
I know a friend of mine told me he runs 110 shafts on the front if his classic but I am not sure about the rear.
Any guidance would be greatly appreciated!
Old May 20th, 2014, 07:29 PM
I highly doubt it.
Salisbury carrier is much larger than the Rover unit.
Old May 20th, 2014, 08:37 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
Troof. -Jeff
Could the difference in width between the diff be compensated for by the shorter shaft on the one side?
Old May 20th, 2014, 08:46 PM
He is talking about axle shafts. They are the same spline, but different lengths. Even disc to non disc sals are different lengths.
Old May 20th, 2014, 09:04 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Nope they are different on one side for sure. If it an older truck with drum brakes the axle shafts are 3/4 of an inch longer than the disc brake sals. Also the drum brake sals run wet as the stub axle doesn't have the seal and the axles do not have the raised portion for the seal.
Old May 20th, 2014, 09:16 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
It would be disc brake Salisbury axel shafts to a disc brake rover rear.
Old May 21st, 2014, 06:14 AM
Capt Milks's Avatar
Capt Milks
Absolutely the short side sals is shorter and I forget if the long side is the same or a bit shorter too. The Sals shafts are a thicker diameter like some of the aftermarket HD shafts.
Old May 21st, 2014, 06:50 AM
Best comparison between the two is think of the 90/d1/RRC having a Dana 44 size axle and the Salisbury as the Dana60.
It's called Salisbury because it was made in Dana's Salisbury England factory
Pics of HD rear axle vs stock axle? josh-man Defender Technical Discussions 22 July 4th, 2017 04:22 AM
1997 D-90 rear axle housing and 83' 110 front axle housing Tyler Wirken For Sale - Parts 0 January 3rd, 2012 06:31 PM
Salisbury Axle with a welded on stub axle, disc brakes, Factory? Capt Milks Defender Technical Discussions 5 December 21st, 2010 09:45 AM
Series III Rear Axle (Drum-to-Drum or Axle Housing) Lriwater Wanted 0 September 7th, 2009 08:08 PM
Axle or axle casing Departing90 Wanted 0 May 29th, 2007 08:45 PM
