Rear axel breather tube - Defender Source
Old May 10th, 2012, 01:54 AM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
I found my rear axel breather tube missing and have a stock replacement set to put in, but don't know where it runs. The existing banjo bolt is on the left side of the axel and points right. The obvious ending point seems to be high up in the wheel well, but I was thinking of routing it thought grommet into the speaker housing.
Where is the stock location and any drawbacks putting behind the speaker?
Old May 10th, 2012, 07:04 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
The higher the better. My stocker was just under the bottom of the tub. I too had gotten new lines and was able to get it higher and out of the way of any splash up.
Land Rover 110
Old May 10th, 2012, 10:47 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Mine runs all the way to the bottom of the bonnet in the engine compartment.
Old May 10th, 2012, 10:53 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I did the same...actually have the tube wrapped around the air intake
Old May 10th, 2012, 01:18 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
Thanks guys. I'll run it as far as it will go with the stock length. In the future I may run all the breathers to a common location under the bonnet.
Help With Rear Mudflaps mhansen Defender Technical Discussions 25 April 17th, 2011 01:56 PM
weak rear brakes? redrover Defender Technical Discussions 12 April 28th, 2006 09:24 AM
rear roll cage, rear seat, soft top surfd90 Wanted 0 January 12th, 2005 02:59 PM
rear diff and rear seatbelts for '94 D90 rover_rich_d90 Wanted 1 April 20th, 2004 08:54 PM
