Rear access - Defender Source
Old October 18th, 2012, 11:25 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Rear access
I'm planning on putting a set of lock and fold seats in the back of my truck. The thing I'm wondering about is how to access the seats once they are in the down position. Then it occurred to me that the owners of soft tops with bench seats must have a similar situation. When the bench is up how do passengers get in?
Old October 18th, 2012, 11:32 AM
1 foot at a time or fold down the front seats and get in that way.
Old October 19th, 2012, 12:52 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Thanks. I didn't know that the front seats fold down.
Old October 19th, 2012, 06:31 PM
ndrenfro's Avatar
ndrenfro
Nathan Renfro
1997 Defender 90 SW
I've got the lock & folds in my SW and my kids (4&6) just crawl around them from the back.
Old January 5th, 2013, 12:59 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
I got my seats and am installing them but I am wondering where the folks with these seats in a sw mounted the over the shoulder seat belt retractor....
Old January 5th, 2013, 01:27 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Interested!
Old January 5th, 2013, 01:36 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
When I added a rear bench to my SW I bought the rear belts and corner mounting brackets for the new style puma rear seats. The corner bracket bolts into the rear corner. Here is the old post:
http://www.defendersource.com/forum/...7&postcount=43
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old January 5th, 2013, 03:01 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Those look like exactly what I was looking for... For some reason I can't see a full sized version of the parts breakdown. Do you think you can give me the info I need to pick those up and a parts breakdown pic?
Old January 5th, 2013, 03:04 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
I thought the Lock and Folds came with the appropriate brackets to mount the included seat belts but I guess not?
Old January 5th, 2013, 03:11 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
The instructions say to find a mounting point at the rear corner but you would basically be fitting it through sheet metal.
Old January 5th, 2013, 05:53 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Ah ok. Thanks. Curious, Did you consider the wheel well mods to fit the Puma folding seats instead of these Exmoors?
Old January 5th, 2013, 08:22 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
I didn't even know that it was an option when I ordered my seats.
Old January 5th, 2013, 08:35 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
http://www.safarihp-trim.com/index.p...mart&Itemid=13
obviously, you gotta buy both sides - fits right into the upper corners..
-Ren Ching
Old January 5th, 2013, 08:50 PM
ndrenfro's Avatar
ndrenfro
Nathan Renfro
1997 Defender 90 SW
This is correct. It's what I have with mine. You have to buy them separate from the seats. I also just removed the rear plastic trim on each side as well. Else you'll end up cutting most of it away anyway to fit the belt retractor.
Old January 6th, 2013, 01:05 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Yah, I did a bit of research and found that there is one type for NAS and one for earlier ROW trucks... How does it look on the outside of the truck... Are there a bunch of bolts sticking out or does it use preexisting bolts?
Old January 6th, 2013, 07:13 AM
Reese_D90's Avatar
Reese_D90
Reese
It uses existing holes at the top and bottom (bolts at the top to the roof section and at the bottom to the tub). You unbolt a few of the existing bolts, slide the part in place, and reinstall the bolts. Then you need to work the trim piece back in place and drill the hole for the upper shoulder belt bolt to go through the trim piece. Once all back together, you cant tell its there from the inside or outside. See my pics above.
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old January 21st, 2013, 10:58 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
I ordered a set of these in and my garage is telling me that they don't fit??? I have a 97 NAS sw... They should work with no problem right or did anyone have any issues?
Old January 22nd, 2013, 01:17 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Okay so the deal is that the bolt that goes drone the top of the rollcage segment in the corner to the bottom of the piece that gets installed is too short. Only a few threads show through when the washer is put on.... Anyone else have this happen?
Old January 22nd, 2013, 01:40 PM
Seem like they worked just fine for others.
http://www.defendersource.com/forum/...ad.php?t=40026
Old January 22nd, 2013, 09:21 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Originally Posted by ndrenfro View Post
Here's a couple shots. You can see the black brackets you have to buy separately to attach the belts.
The pics from the other thread show the top of the bracket... No prob there... It's the bottom stud that doesn't come up far enough...
------ Follow up post added January 22nd, 2013 06:22 PM ------
Oops no pics came....
ac
Rear diff replacement options cgalpin Defender Technical Discussions 20 July 14th, 2007 01:21 AM
Rear Bench Seat + hardware Chaucer For Sale - Parts 8 September 29th, 2005 12:16 AM
rear roll cage, rear seat, soft top surfd90 Wanted 0 January 12th, 2005 02:59 PM
rear diff and rear seatbelts for '94 D90 rover_rich_d90 Wanted 1 April 20th, 2004 08:54 PM
