So when you buy an elite rear ac system etc... How do you tie into the lines and run lines back to the unit in the rear? Also can the stock compressor on a 1997 4.0 run two condensing units? So if you tapped into the lines and put t's in them to add a second unit in back will the system handle that load?
Thanks for the help.
Tyler
Tyler
