Rear AC Evaporator Location Suggestions? - Defender Source
Old September 9th, 2013, 12:26 AM
BlackField's Avatar
BlackField
Oscar
D110
I am in the final stages of AC component gathering. I have ripped out my old heater box and am just about to start throwing AC parts at the truck.
anyone have any pictures of rear mounted AC parts? like if someone stashed it in a wheel well, under a seat, any input and pictures would be appreciated.
I've considered moving my battery elsewhere to fit the evaporator under the drivers seat since it appears there is a little more room in there compared to the passenger side.
My Aux air box is about 8.5" by 11.5" its basically the same dimensions as the one Im going to run under the hood but without the heater core.
Oscar
Old September 10th, 2013, 12:51 PM
blenkush's Avatar
blenkush
Severin Blenkush
97 D90 LE, 10 Lotus Exige S, 05 LR3
rear A/C
Oscar,
Go to the parts for sale page and search "Defender rear A/C or heater ducts". I sold a pair of these a while back that had come out of a 110 and included a bit of information how it had been installed in the vehicle I removed them from. From your description I wasn't sure if you were adding rear A/C to an existing system or setting up an entirely new one. The 110 I saw had two evaporators, one in the center cubby and one behind the left rear wheel. The evaporator behind the wheel was in a self contained ABS plastic box that incorporated a blower that would suck interior air through a hole in the vertical wall of the wheel well, push it through the ABS box and the evaporator, and then up through a hole in the horizontal wall of the wheel well through the vertical vent along the c pillar and out the horizontal vents along the roof.
Cheers,
Severin
Old September 10th, 2013, 01:09 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
Very interested on how this turns out. Please keep us posted. Where did you source the parts?
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old September 11th, 2013, 07:46 AM
Reese_D90's Avatar
Reese_D90
Reese
This summer someone posted an install of a blower inside the truck under the middle seats of a 110. It was an after market system like "old air" or "classic air". It included the condenser and fans for a split system under the truck against the chassis rail.
I cant find the thread now.
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old September 11th, 2013, 08:24 PM
BlackField's Avatar
BlackField
Oscar
D110
Severin,
thanks I posted on your for sale post. I thought I posted a thank you yesterday but it looks like it is gone.
Reese,
Im using a mismatch of parts from both Old Air Products and Nostalgic Air.
I will use the same format that Piekas and Wolfabrication used on their AC threads so all the part numbers and components are listed.
Oscar
ac
Rear diff replacement options cgalpin Defender Technical Discussions 20 July 14th, 2007 01:21 AM
weak rear brakes? redrover Defender Technical Discussions 12 April 28th, 2006 09:24 AM
Rear anti rock redrover Misc. Chit-Chat 11 March 22nd, 2005 08:43 AM
rear roll cage, rear seat, soft top surfd90 Wanted 0 January 12th, 2005 02:59 PM
