rear abs sensors - Defender Source
Old March 21st, 2010, 05:59 PM
gas-man's Avatar
gas-man
Robert/Mazzarella
97/D90 ST: Sold
rear abs sensors
Following the advice on previous threads, I removed my 4 ABS sensors to clean and re-lube them with dielectric grease in order to clear the rough road fault. The front sensors went in no problem, but the rear sensors don't seat all the way flush with the housing. When fully inserted, the sensors bottom out with approx 1/2 inch still protruding as shown in the attached picture. It has been 2 weeks since I removed the sensors and now I can't remember if the sensors stuck out that far initially. Can someone confirm that my rear sensors look fully seated? Thanks.
ID:	25881   Click image for larger version
Old March 23rd, 2010, 11:47 AM
gas-man's Avatar
gas-man
Robert/Mazzarella
97/D90 ST: Sold
Bump.
sensor
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Dreaded Emissions Test and P1317- ABS Rough Road d90xj Defender Technical Discussions 3 October 24th, 2004 01:23 PM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
