Rear A arm question - Defender Source
Old November 2nd, 2015, 01:17 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Rear A arm question
Quick question on parts compatibility. Will the rear A arm (upper link) on a Defender 110 interchange with a Disco?
It looks like the brake brackets are dfferent (cast on the defender) but the link arms, ball joint and other bits may be the same?
JL
Old November 2nd, 2015, 01:21 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Same part, unless referring to the bracket that holds the ball joint. Those are not all the same
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Yes, you can swap it out with one from a disco. Not sure what "brake bracket " you're referring to
Old November 2nd, 2015, 01:55 PM
The triangle guys on top I assume.
Old November 2nd, 2015, 04:01 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Thanks guys. I meant chassis brackets, the triangle ones that Evilfij is referring to.
For the ball joint bracket that bolts to the arms, is the only difference boge unit vs. non-boge unit?
JL
Old November 2nd, 2015, 04:04 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Yees
Old November 2nd, 2015, 04:20 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Pick and pull disco here I come!
Thanks guys.
JL
Old November 2nd, 2015, 04:27 PM
Thanks guys.
Getting one off in a junkyard in Canada with all the rust should be fun.
Good luck. I can't imagine how you broke one in the first place or why you need it. If you just want to eliminate the boge you can cut that part off.
Old November 2nd, 2015, 04:32 PM
What are you trying to accomplish? You can buy the ball joint and its holder together for not a lot of money.
Old November 6th, 2015, 11:18 AM
oilburner's Avatar
oilburner
JL
large pile of parts
I bought a rolling chassis with these parts missing. Trying to piece things together so I can move it around easily. I figure it will be easiest to get the whole A arm as an assembly. Cordless sawzall to cut the frame mounts off.
JL
Jointed rear radius arm installation question 89Defender90 Defender Technical Discussions 5 March 31st, 2015 06:54 PM
Rotor Arm replacement 3.9 v8 - quick question silverlight Defender Technical Discussions 10 September 6th, 2011 01:07 PM
Radius arm and trailing arm nut size dave_lucas Defender Technical Discussions 3 February 25th, 2010 04:44 PM
Radius Arm Bushing Question Craig T Defender Technical Discussions 4 April 16th, 2009 09:02 PM
Pitman arm to Steering box question dmarchand Defender Technical Discussions 3 September 5th, 2008 11:53 PM
