Rear a arm castel nut - Defender Source
Old December 21st, 2013, 04:01 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Anyone know what size wrench I need for this nut?
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old December 21st, 2013, 05:30 PM
lordhelemt's Avatar
lordhelemt
Paul
Thanks my 1 1/8 didn't fit. Will buy a 30mm. Thanks
Old December 21st, 2013, 06:13 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I've replaced the A-arm joint once.
Once.
I don't want to do it ever again.
Rent my
Old December 21st, 2013, 06:18 PM
Once.
they now come complete with a carrier ... much easier
Old December 21st, 2013, 06:45 PM
Or if you have a Snap-on addiction
http://store.snapon.com/Standard-mm-...t-P630751.aspx
-Jeff
Even though I own a ton of Snap On tools, I get sick looking at the prices.
Old December 21st, 2013, 06:53 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
It's not so bad. If you have a press, swapping the just the ball I'd strait forward. If you dont have a press, get the the ball already in the cast piece. -Jeff
I brought mine to the machine shop behind the local Napa. He said no charge but I gave him a 20. I just noticed RovahFarm has the complete setup all clean and painted for $100 which what I would do if I had to do it again.
Old December 22nd, 2013, 02:46 PM
lordhelemt's Avatar
lordhelemt
Paul
It appears the bolts rusted through the fulcrum and a-arms. the nuts came off easily but I'm not able to remove the bolts from the fulcrum. Has anyone encountered this before? Is it possible to remove the bolts or am I SOL?
Old December 22nd, 2013, 02:49 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Some localised heat might help:- oxy acetylene that is
Mike Hammond
Old December 22nd, 2013, 03:15 PM
Rusted...yes. At that point you should pull the whole A arm and work on it separate from the truck. Use heat, drizzle ATF into the gaps,more heat, then impact gun. I've also found cussing/swearing helps.
-Jeff
When I did mine - and it wasn't rusted - I just pulled the entire arm. It's like a couple of bolts both sides....but then again I think that castel nut needs to come off to get the arm out, doesn't it?
Old December 22nd, 2013, 03:17 PM
lordhelemt's Avatar
lordhelemt
Paul
The whole a-arm is out and I've tried plenty of cursing and it hasn't helped.
Will try some heat and see if I can get them to break free but i'm not hopeful. I may just try cutting the fulcrum out and just try to save the arms.
You're never SOL
A MAPP gas torch, a hardened punch with a hammer, among other things can be used to do the job.
Old December 22nd, 2013, 03:21 PM
Not sure I'm visualizing this correct, but when I did mine (and it wasn't even rusted in) I just cut the ears off the ball-joint housing as it was in place on the A-arm. Then I was able to use a press to get the leverage needed to actually press the entire ball-joint housing out (with the "ears" on you can't get the leverage needed).
Old December 22nd, 2013, 03:34 PM
mikeslandrover
Mike Hammond
If you take the whole shooting match to a shop with a press they might just manage to press out the ball joint with the 'A' frame complete.
Mike Hammond
Old December 22nd, 2013, 03:41 PM
lordhelemt's Avatar
lordhelemt
Paul
So you have the this, and not just the ballpoint?
Alternate heat and ATF, the impact and wacks with a hammer in between.
-Jeff
I can't get that off the arms
Old December 22nd, 2013, 03:52 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
That balljoint is fine, put it back on....
Seriously, I'm glad to see you can buy the whole piece now.
When I replaced one of mine 6 years ago, I did just the joint and put a Rovertym A-arm extension in there.
I'll probably pull that whole piece as the truck is being parted and it only has about 3000 miles on it!
Rent my
Old December 22nd, 2013, 04:39 PM
mikeslandrover
Mike Hammond
If you have an adjustable ball joint you could undo it, clean it, repack it with grease, tighten the play out of it and you're good to go.
Mike Hammond
Old December 22nd, 2013, 06:39 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I had one bolt that was murder to get off. When reinstalling, I but an insane amount of anti-seize on for the next person who has to deal with it.
Old December 24th, 2013, 09:47 PM
lordhelemt's Avatar
lordhelemt
Paul
Thanks. Looks like a lot of swearing does work.
Old December 25th, 2013, 03:07 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Just saw this, yeah, mine was a real B***h to get off too. I pulled everything and then it took a couple days of soaking in penetrating oil, heating it, using a press, using a BFH and using an air hammer, but eventually they came out. I ordered new bolts from McMaster to replace them.
Rear A arm ball joint DesertRat Defender Technical Discussions 9 November 27th, 2010 04:42 PM
d90 sw rear wiper motor and arm lspindler5 For Sale - Parts 1 August 7th, 2010 10:41 AM
d 90 sw rear wiper motor, bracket and arm lspindler5 For Sale - Parts 5 July 21st, 2010 04:49 PM
weak rear brakes? redrover Defender Technical Discussions 12 April 28th, 2006 09:24 AM
rear roll cage, rear seat, soft top surfd90 Wanted 0 January 12th, 2005 02:59 PM
