Rear A arm ball joint - Defender Source
Old November 26th, 2010, 07:38 PM
DesertRat
Bryan Barnes
95 D90 2.8TGV
Replacing the rear A arm ball joint and all the bushings. I was able to get all the bolts/nuts
loose surprisingly easily but I'm stuck (literally) on the final point. Guess I should say I'm
removing the entire A arm. Everything is loose except the ball joint itself from the axle housing
bracket. The castle nut came off pretty easily. Is the ball joint threaded into the axle bracket?
I put the other 2 ends of the A arm back into their brackets and placed the jack under the end
that attaches to the ball joint end. I lifted the whole weight of the Rover about an inch off the jack stands
and it didn't let go. I've PB Blastered and hammered the crap out of it. Would welcome any suggestions
and an answer to the question above.
Thanks guys.
Bryan
Old November 26th, 2010, 08:06 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Hit the housing with a big hammer. It is not threaded into the axle housing, it's just a regular big tie rod end. Rocking the truck forward and back can help too.
Old November 26th, 2010, 08:14 PM
DesertRat
Bryan Barnes
95 D90 2.8TGV
Thanks Kevin
Let the pounding continue.
Old November 27th, 2010, 04:06 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
What i tend to do, is refit the large castle nut (only on a few turns,) then with the aid of a long bar or somesuch, smack the "end" of the threaded bit upwards, this usually free's it off (the nut stops the whole thing flying out, and protects the threaded part should you be just changing the axle.... so obviously if the ball joint is FUBAR'd anyway, you won't be worried about saving the threads on the end of it)
Like Kevin says, it's just a tapered fit, once it's been loosened it just comes out.
Old November 27th, 2010, 07:48 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
You might try a traditional tie rod removal tool or "pickle fork." Usually about $10 at the auto parts store.
Semper Fi!
Old November 27th, 2010, 09:25 AM
Mark McDonough's Avatar
Mark McDonough
Mark McDonough
66' IIa, 95 D 90 300 Tdi, 94,98 D1
Ball Joint
If you have the assembly off the truck and it was anything like mine, take it to a machine shop with a big honk'in press. I gave up after shop press tools, ball joint tools and lengthy beatings.
Basically it should be fixtured under a decent sized press and pushed out
Old November 27th, 2010, 03:18 PM
DesertRat
Bryan Barnes
95 D90 2.8TGV
Thanks guys. I ended up putting some pressure on it with the jack....just enough to start
to lighten it up on the jack stands. Then I followed Kevin's advise. Beat the sh*t out of the housing.
After a couple of minutes it finally let go.
Mark...I was able to tap the ball joint out the housing, but I will going to a machine shop
to press the new one in.
Now, on to sand blasting and chassis paint.
Thanks again.
Old November 27th, 2010, 03:33 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Top tip.... get some threaded bar, or a couple of bolts that fit the thread in the ball joint "holder" (later versions are M8 thread, earlier ones are some stupid imperial thread, can't remember what it is at the moment)
anyhow, screw in a couple of bolts, and offer the ball joint up over said bolts prior to pressing it into place, this makes sure that it goes in "square" over the holes, so that you can then insert the proper fixing bolts. nothing worse than pushing the ball joint in then finding it's out of line with the mounting holes.
Old November 27th, 2010, 03:58 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
You guys are making this way too hard. Next time, loosen the castle nut so you see a gap. Leave the nut on. Before you loosen any other bolts, go driving around. Hit the brakes a few times. Done.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 27th, 2010, 04:42 PM
Wolf Fabrication
Sterling Archer
'08 D3
That's a good way to do it, but I think he was way past that point!
Semper Fi!
steering drop arm ball joint souza Defender Technical Discussions 20 February 29th, 2008 11:41 AM
Rear Ball Joint Buckon37s Wanted 4 April 9th, 2006 06:54 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
rear ball joint mattdh Defender Technical Discussions 3 October 13th, 2003 04:28 PM
